BUILDING THE MKII MCB FUNFLY.
01 Nov 2012 05:51 #61 by Phil Wood
Replied by Phil Wood on topic Re: BUILDING THE MKII MCB FUNFLY.
Yeh, looks a good'n Tony .... it's got a long enough nose so that it shouldn't need any excess lead weights.... you can always move equipment rearwards. ;)
It's got simple lines & should be within the grasp of a moderate builder .... And it's got a sporty look about it .... I think you've hit on a good design here mate. ;)
01 Nov 2012 14:00 #62 by Ex-Member
Replied by Ex-Member on topic Re: BUILDING THE MKII MCB FUNFLY.
The nose is designed to hold a 2200mah 3s battery in front of the wing leading edge, thats why it's so long.
if you cut the l/e spar out where it goes through the fuselage you could slide the battery back, but that might weaken the wing.
also on the mkI the cog is spot on without any extra weight added, though with the bigger motor it is now slightly nose heavy, but i think adding a tail wheel will balance it out again.
MCB LOOPY is nearly ready for the off. :cheer:
anyone want a kit or artf version.
01 Nov 2012 18:05 #63 by Ex-Member
yellow wing tips.
ailerons covered now.
just got to put it all together and do the dreaded wiring.
08 Nov 2012 00:58 #64 by Ex-Member
Just need to connect up the control surfaces now and we are done.
13 Nov 2012 22:54 #65 by Ex-Member
Well it is finished. i think
just need a battery and rx and it will fly.:cheer:
14 Nov 2012 00:52 #66 by old fart
Replied by old fart on topic Re: BUILDING THE MKII MCB FUNFLY.
What a nice looking model. :cheer:
14 Nov 2012 02:13 #67 by Garry Pollard
Replied by Garry Pollard on topic Re: BUILDING THE MKII MCB FUNFLY.
It should fly right, as it looks right. Well done Tony
14 Nov 2012 04:04 #68 by The Beard
Replied by The Beard on topic Re: BUILDING THE MKII MCB FUNFLY.
Looks great Tony looking forward to it,do we need to talk.
18 Nov 2012 23:29 #69 by The Beard
Your toying with me, Im eager to get my hands on this one and your deliberately spreading it out,by even choosing the colour of a carrot,,well on the wings anyway.
Time to create page: 0.283 seconds
