Quadcopter
22 Nov 2012 20:22 #1 by Klipkopwildlife
Quadcopter was created by Klipkopwildlife
Ever since I've failed, sometimes spectacularly, to fly rotary wing aircraft I've always wondered about Quadcopters but, whenever you go on to Hobby King there's such a bewildering number of bits and pieces you don't know what the hell to order!
So, when I was offered a quadcopter kit, complete, for an apparently reasonable price (90quid) I grabbed it, and got burned!
Here's the story.
22 Nov 2012 21:12 #2 by Phil Wood
Replied by Phil Wood on topic Re: Quadcopter
Come on Klippy, I'm falling asleep here :lol:
22 Nov 2012 22:47 - 22 Nov 2012 22:47 #3 by The Beard
Replied by The Beard on topic Re: Quadcopter
And what happened next zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz :woohoo:
Last edit: 22 Nov 2012 22:47 by The Beard.
22 Nov 2012 23:14 #4 by Garry Pollard
Replied by Garry Pollard on topic Re: Quadcopter
Its a soap opera
Next episode will be on here tomorrow. Bet its better than Corrie :evil: :evil:
22 Nov 2012 23:29 #5 by The Beard
The tension and anticipation are building :woohoo:
22 Nov 2012 23:30 #6 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: Quadcopter
Garry Pollard wrote: Its a soap opera
Corrie???
Back by popular demand!
The whole thing arrived in this box
And this is what I found inside
22 Nov 2012 23:31 #7 by The Beard
WOW exiting ---A BOX :woohoo:
22 Nov 2012 23:34 #8 by Klipkopwildlife
Notice the complete absence of ESCs and motors, The foam box at the top right is the controller, what is immediately apparent is, it's not a build but an assembly! The motors are in fact underneath the bits! I'm still waiting for the ESCs. The arms come already assembled.
23 Nov 2012 03:23 #9 by Eric
Replied by Eric on topic Re: Quadcopter
I've had a falling-out with hobbyking - I ordered a Salto kit from the UK warehouse. The order was acknowledged, as per, and a despatch email sent, and I waited, and waited, and waited.
(and waited). After a month I sent an email saying non-delivery, which was acknowledged.
Another fortnight went by, then a very battered card box turned up from Hong Kong!
When I opened it, there was a glass Salto fuz, a pair of wings, a broken Vee tail, a steel bar, and a bag of screws, all individually bagged and taped to the bottom of the box.
No instructions of any description. The fuz is not drilled for the locating pegs for the wing, although it is for the steel joiner, and it is not drilled for the tailplane mount. Nor is there any way of getting in to the underside of the tailplane mount without butchering the fuz.
I photographed the bits, and sent the images to HKing.
After a lot of back and to, and another load of emailed photo's, they've offered me a partial rebate.
23 Nov 2012 14:42 - 23 Nov 2012 14:48 #10 by Klipkopwildlife
This came from a local guy, he admitted he'd forgotten the ESCs but never sent them to me!:angry:
This is the controller, I'm already worried because there's signs of soldering on the back!:(
The arms come pre made and must be bolted to the centres. Hobby King stuff never comes with instructions! On the web site you must go to the item, then scroll down to the bottom of the page, then click on the 'Files' tab, everything you need is there to be downloaded.
Last edit: 23 Nov 2012 14:48 by Klipkopwildlife.
23 Nov 2012 15:27 - 24 Nov 2012 19:27 #11 by Klipkopwildlife
The arms
First mistake, I assembled all the arms onto the centre pieces!
You can't get the ESCs in!:angry:
Note one arm is a different colour, this will be the leading arm when flying forwards. The Control board comes pre-programmed to fly + configuration, that is one arm leads. You can re-program to fly X configuration, which I understand is more stable.
Last edit: 24 Nov 2012 19:27 by Klipkopwildlife.
23 Nov 2012 23:52 - 23 Nov 2012 23:53 #12 by Klipkopwildlife
The copter itself is the V1, priced at $11
The motors are marked BL-2212/13 and are no-name brand
The control board is the Control board version 2.1 $12.99
and the ESCs are TowardPro 18amp $9.99
The web site says they are TowerPro, this is a lie, they're knock offs!:angry:
Last edit: 23 Nov 2012 23:53 by Klipkopwildlife.
24 Nov 2012 17:02 #13 by The Beard
This is all very unsatisfactory isnt it and virtually impossible to complain to anyone and get a satisfactory response.
24 Nov 2012 19:17 - 24 Nov 2012 19:25 #14 by Klipkopwildlife
Stephen, had I bought direct from Hobby King it would have been Ok, but no. I bought direct from a middle man who frankly ripped me off!:angry:
The inner bits have to be separated
And the UC legs
Looks very flimsy to me!
Last edit: 24 Nov 2012 19:25 by Klipkopwildlife.
24 Nov 2012 20:15 #15 by Klipkopwildlife
The motors are simple to fit, a large number of 3mm nylon screws and nuts are supplied, once again my local man ripped me off and I had to order more from HK.
I found that I could get the ESC inside the arm.
As the assembly goes on you're conscious of adding weight, do not be tempted to use steel nuts and bolts!
Time to create page: 0.275 seconds
