What next?
I have a mental note for another scale job, an EDF Canberra PR9 but with the ducts to scale. Given the slim lines of the RR Avon this would be quite a challenge. It is such an elegant airframe.
I also have a single axis giro (actually I have two!) so I am musing over what to do with it and in what airframe.
Finally I have decided to 'retire' my Dads home built petrol 5cc four stroke which incidentally was made some 12 years before OS released their first 4 stroke in 1974.
I had hoped to fly it and although it runs fine with a big coil it is hard to start and ticks over poorly on a miniature one. I could buy a CD system but it would require some modifications to install it.
This coupled with its irrepairable nature (at least by me!) means that flying it is too big a risk so it is returned to its original display stand that my Dad made which is securely located in a custom wooden box.
Never intended for aerobatics it has a float carburettor. The original side float version (below) was replaced by one with a annular float and a bigger venturi.
It runs on straight petrol as it has a dry sump lubrication system.
- Inactivated User
The problem is really its coil/contact breaker ignition system. As its only 5cc it really can't carry too much dead weight.
On an 12V automotive coil it runs very well and starts with the flick of the finger.
However on a miniature 3V job the spark is weak and that's when starting/slow running becomes the problem and without reliability the risk of crash damage is just too great.
In terms of engine hours there is no real problem as it was designed specifically for long life, hence the positive lubrication system. Indeed you can see from the smoke in the video the lubrication is rather too positive at low revs. It really needs an oil control ring as well.
The only drawing I have is this GA which my dad drew up for a Model Engineer article.
- Inactivated User
As a lad specially made toys were never a problem but having decided to go into engineering myself it did seem his footsteps were always there before me.
As an apprentice in Shropshire I bought my first car (a Mini) from the Waverley garage in Wellington (now Telford). The deal was concluded by the senior salesman who must have been getting on for 70. To my surprise he recognised my surname and said he had sold a car to that name many years before.
Indeed he had. A Morris 8 to my Dad in late 1945. He had been stationed there during the war developing AA guns.
I was extremely fortunate to gain my companies sponsorship to study Industrial Engineering and Management at Loughborough University starting the following year.
I couldn't wait to tell my parents on my next trip home to Kent (my Dad worked for the MOD in London).
My dad just smiled on hearing my news and with a gllnt in his eye calmly informed me that in his senior R&D role he had been asked to identify a possible individual to head up a new Design Engineering Department at Loughborough Uni and would you believe it - he had accepted the post himself!
Oh no! My Dad as my teacher!
Fortunately he only taught PhD post graduates so few of my fellow students even knew who he was - but it did mean my Mums home cooking was close by!
It used to flood quite regularly around Quorn where they lived. Happy days, I had hair then. Note the exhaust bubbles!
And so it when on.
Even many years later when I moved into the nuclear industry and went to Sellafield he knew quite a bit about the original plutonium producing reactor 'piles' as he had been involved with the Uranium fuel rod feeding mechanism that in many ways was similar to the automatic shell loading system used on the 4.7" AA gun!
Enough story telling - I still have to decide on what to build next!
- Inactivated User
It was driven very carefully into the water and it did have the benefit of a Marigold rubber glove over the distributor! The approved 'rain fix' until BMC brought out their specially moulded cover.
If I take a 55mm fan (as I used in the scale V-1) and place it at the front of each engine nacelle to give a scale 55mm diam jet pipe it comes out at a whopping 2m span and just over 2m long. oo-er! and it would have a wing loading of under 5oz/sqft!
I suppose I could go to 40mm EDFs which would give a more manageable 1.45m span but the thrust to weight ratio becomes rather more critical.
To quote Fagin:
"I think I better think it out again"!
Virtually identical to the F1 Lightning in overall shape except for the cockpit and the nose intake.
The intake is quite large, at least equal to the area of the double jet pipes.
So a lightweight single fan EDF with a scale inlet and jet pipes looks possible.
With a maximum size duct running nose to tail the challenge will be to find somewhere to put the battery.
They are a typical fit for prototype aircraft for accurate speed and angle of attack measurement.
- Thank you received: 10722
I would have put it on here but dont know how
