TELEMASTER
bloody big builds i get stuck with.
Is the Telemaster yours (where do you put it?) or are you building it for someone?
nothing is ever mine.
i have 2 models that are mine and one of them is an artf.
it's all in imperial, so i will have to convert everything to metric and make a HUGE list.
bound to forget something though.
might need an artic to get the stuff back home.
- Dean M
- Thank you received: 326
Have you seen this one on YouTube? It is Electric powered although it is the ARTF version
I nearly choked on my latte.
its all in imperial measurements
got a rough idea now, but i expect i will miss something and have to order it later.
still i should be able to get the basic frame done fairly quickly.
might get 3 ribs cut from each sheet of balsa if i am lucky.
At that size I would have thought it would be possible to use 'built up' wing ribs and save on a lot of sheet balsa!
the whole tail bolts on, so the center ones are a bit more complicated.
run out of 3mm balsa now anyway, so no more till after the nats.
the issue was that i only had a view of the center ribs, i have had to extrapolate what the rest look like.
sooooooooooooooooooooooooo
after clearing some bits out of the workshop (i need more room, or less models) i did a little bit more.
finished cutting the ribs and cut some strip (thick strip) and started building.
The tailplane is 4ft wide, thats the same size as my funfly main wing. eeeeeeeeeeeeeeeeeeeeeeep.
i need to make up the ply center ribs and wing braces and wing mounts next, then i can put the leading and trailing edges on and start the elevators.
