- Thank you received: 833
1/3rd scale Sopwith Strutter
- CeeJayP
- Hi Peeps
cjp
- murdoch
- Senior Member
1st sort out whats what
the longrons are ½ x ¾ but could not find any spruce that size, so went into my local Jewsons and found 8ft lengths of pine that does the job.
Next was boxing up the longrons with 1/32 ply.
The 1/32 strips of ply supplied was not wide enough to box the forward longrons, so waiting for more materials to come.
The leading edge is glass-fibre rod
I was not keen on the 1/8 x ½ balsa bracing so went for the real thing of bracing wires.
Will have more soon.
wish i could build as well as that.
- Dean M
- Thank you received: 326
I nearly choked on my latte.
- murdoch
- Senior Member
Showing the wire attachments, I used small solder tags with ply plates for strength against the balsa ribs, fixed with 2mm nuts & bolts
- murdoch
- Senior Member
- murdoch
- Senior Member
still thinking of the best way to either join the wing panels to the stub wing that has the air brake and plug that onto the fuselage or fix the stub wings to the fuselage.
The plans don’t give a lot of information on building even some annotations are missing and limited on the amount of detail.
Started putting the tailplane together, found the riblets where to short so cut more to fit but will press on
tips on and wire tensions are done, elevators next.
i am still in awe.
- murdoch
- Senior Member
But I must say if I was going to the trouble of fitting cable pulleys I would have be very tempted to actually use them and have scale control runs as well.
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
Looking lovely Murdoch, when I grow up I want to be able to build like this
- murdoch
- Senior Member
- murdoch
- Senior Member
Well I have finished doing the tailplane, just some minor things to do on it when time to fit to the fuselage.
Ribs are 2 1/32 ply glued together with 1/32 ply trailing edge
Then bending and adding the 14swg piano wire trailing edge
Then finally making up the s/s horns, the elevator hinges are cotter pins clipped together.
Next is finishing off the top wings, not been doing much to it over the Christmas period.
So Happy New Year to all, and lets hope for some good modeling and flying for the coming year.
murdoch wrote: Ribs are 2 1/32 ply glued together with 1/32 ply trailing edge
Why can't you just use 1/16 ply instead of gluing to 1/32 together?
