- Thank you received: 2182
BMFA Dart
- Sarah-Jane Smith
- Gone
So here is prolly the smallest build thread in history haha!
First, with a little help from little people (my niece and nephew) we laid out all the equipment . The BMFA frog comes with all the balsa strips needed, paper covering in the form of outlines on paper, prop and rubber band. All we had to provide was the glue, cellotape, pins and a craft knife. Jobs a good un!
Not having made the work board yet we had to settle for a piece of cardboard, as the instructions suggest.
Placing the printed side down on the board we taped it carefully
Then after cutting a small section of the paper denoting the fusalage (towards the rudder) we glued the balsa fusalge onto the plan, pinning it into place.
- Sarah-Jane Smith
- Gone
cutting into the plan along the edges we folded over the paper flap at the top of the rudder- it wouldnt stick at first and took a few goes but we got there in the end!
Next we worked on the wing frame, cutting the pieces to fit perfectly we framed the wing and glued each joint to each other. Note to self, learn to read instructions- it said dont glue to the plan yet....ermmm ooopsie
- Sarah-Jane Smith
- Gone
Looks pretty good but doesn't the Dart wing have dihedral?
Or is there a way it is added later?
- Sarah-Jane Smith
- Gone
After cutting the wing and tail out following the wood along the plan we glued the paper flaps as we did with the rudder then after adding the propellor onto the fusalage we glued the wings to the fusalage, pinning it in place. The leading edge was placed 32mm from the front of the fusalage as instructed in the plans
and before the glue dried completely we turned it over and pinned it to the board to form a dihedral angle.
We made sure this was completely square and added more glue to strengthen the joints. This was left to dry.
At this points the kids went home and Auntie Sarah hit the baileys- hence no more pictures haha! oopsie.
All that was left to do was to the glue and pin the horizontal stabilllizer to the rear part, remove the pins then putting a pin at a slant at the front end of the tail so the rubber band can be linked around it.
Will continue and get another picture tomorrow..... if it is a breeze less day will give it another go outside.
- Sarah-Jane Smith
- Gone
Quorneng wrote: Sarah
ah ha!
- Dean M
- Thank you received: 326
I nearly choked on my latte.
Don't be embarrassed by your first build - you never saw mine! (good job too!)
I didn't even have a plan - I didn't know such things existed - and all my aerodynamic knowledge could be written on the head of a very small pin with a big black felt-tip marker!
I saved my pocket money, and one week I bought a three foot x three inch x 1/16 sheet of balsa. A couple of weeks later, I bought a tube of balsa cement, and a bit later, a sheet of tissue.
Then I made it up as I went along.
Craft knife? What's one of those? I used a blunt razor my Dad had discarded, and cut myself, the table, the wood, and everything else in reach of it!
Eventually I had a sort-of cruciform shape - (with dried blood fingerprints) - that was nearly the same on both sides, and square - what did that mean? I thought it meant sharp corners, so that's what it had.
Did it fly? er - no! but it would fall through the air as far as I could throw it, which was about six feet. I thought it was fantastic.
- Flytilbroke
- Thank you received: 1978
- Sarah-Jane Smith
- Gone
Got a cricket and a frog to do next
- Sarah-Jane Smith
- Gone
Old Fart wrote: Careful Sarah, frogs eat crickets.
I've a snake under the stairs would eat both of them
- Sarah-Jane Smith
- Gone
The Beard wrote: Very impressed as usual you describe the build very well Sarah congratulations
It's called following the instructions, something you men.......ahem, cough, splutter.........
- phil claridge
- Thank you received: 106
if in doubt crash
