- Thank you received: 352
Dornier 335
- chookman
- Premium Member
Al marshall's plan at 81" was a little to big for me, so I contacted one of our Laser guys and asked him to reduce the plan down to 73" and supply me a short kit for it.
It is now on the bench being constructed,
I will try to download a pic
- Away
- Thank you received: 10722
got me coffee and biscuits and will enjoy watching this one develope.
tony.
- Inactivated User
- chookman
- Premium Member
Motors , at this stage I am going with Turnigy G46's but allowance will be made at the ft for a G60 if required, the batteries will be 4s 4000hr x 2m and they will be slotted into where the ft fuel tank should be, but they can be moved if necessary, these are just idea's at the mo
The web brings up the build of Al Marshalls model in good detail, instructional build actually,, but it relates to the 60" one and of course I got his 81" plan reduced, didn't I, so altho there are slight differences in the structure, the download is very helpfu
The colour scheme of the full size is of a splinter nature, but there was a night fighter produced with a snow effect scheme ,underside is RLM 65 at the fuz side view it starts to blend into white ( RLM 21 ) with what looks like splashes of RLM 75, much the same pattern as the desert camo
added a few bits last night, but not a great deal
Cheers all
Thanks for the kind words
Barry
www.samsmodels.com/site/dornier.html
Quick question - why go to all the trouble of fitting an extension shaft for the rear motor. It looks like a lot of engineering for very little weight reduction and there'll be a lot more to go wrong?
.....Best of luck with the build!
Surely with heavy batteries required countering a rear mounted motor should not be an issue.
- chookman
- Premium Member
Do ya know that 12ozs of fuel weights close to 375gms, add that to the engine weight an more weight is needed in the ft
Cheers all
Barry
chookman wrote: Do ya know that 12ozs of fuel weights close to 375gms,
Barry
I thought it weighed 12oz.
The batteries (how much are they likely to weigh?) only have to make up the difference in moments.
- chookman
- Premium Member
Cheers
Barry
Not sure why you discounting the effect of the weight of the batteries.
They will weigh at least as much as the pair of motors and possibly quite a bit more. (eg 5000mAh 6s = 980g)
They are free to be placed in any particular part of the airframe and as they don't get lighter as they are used up there is no requirement for them to be placed on the CofG.
The only problem I could see would be if the batteries cannot be physically installed in the required location.
I avoid using ballast like the plague on any electric plane and always use the batteries to achieve the required balance.
