Hangar 9 Hellcat
On looking through my stock, I have I think all the necessary gear to do the job, which Dave will replace.
The supplied and fitted retracts were tested, and found to be working 100% after slight adjustment.
Today,I have installed the servos for elevator, rudder, and ailerons, complete with extension leads.
I shan't do any photos of this , as it is an installation on an ARTF model, but does keep Dave up to date on what is happening
- Inactivated User
- Si_B
- Thank you received: 680
Pictures please
- Thank you received: 10722
n
- Inactivated User
THE BLACKBIRD wrote: How can our leader do a build thread with no pictures, if we tried it we would get a b
n
Ha ha , well one reason is this house does not own a camera, (private matter), and as Alan has pointed out I am only kitting out an assembled airframe, and it is something everyone does on a regular basis . However, unlike Tony, its a job I enjoy
Canopy fitted, not glued , but screwed.
Wing finished, as servos now work as they should, not like inverted flaps .
Motor and ESC fitted, and motor turns the correct way, need to put watt meter on it to test. Cowl now fitted, as is the prop and domed nut which really sets it off
Next, I need to sort out the C of G and lay in a tray for lipo to be mounted on .
Discussed this at length with Dave, and we have both come to the same conclusion that the model is too good to start carving out a hatch for battery access, so this model will need to have the wing removed to change the lipo, but this is no big deal , and will retain its structural strength
Soon be finished
- Inactivated User
Coarse, you can always just remove the wing, YAWN
