- Thank you received: 10722
THE SECOND SR 71
Simon and Tony have realy got me interested in this stuff
So something simple to start with
- Inactivated User
it was on my to do list, but i will let you go first
The SR71 is not the most efficient shape for slow (100mph?) speeds so you really need all the EDF efficiency you can get so my advice is if you can to avoid using cheat holes.
In general fans are much more sensitive to aerodynamic disturbance on the inlet side than the exhaust so cheat holes are an inefficient way of getting a fan to 'breath' .
Do you know how the other EDF SR71s have arranged their inlets?
My ideal solution would be to work out the area of the scale inlet 'ring' and then size the EDF FSA of the fan to match it. The fan may end up rather small but then a Depron airframe can be very light.
I note that at Mach 3.2 the spike was retracted considerably so from the outside it looked like it was rather smaller so it would still be scale with a smaller spike.
'SR71' in Wikipedia shows a nice diagram of how the airflow actually worked at different speeds.
Also emailed Steve Webb but again nothing
Think ill be looking to fit 12 bladed fans in it as they sound so much better
never had a problem before.
Still looking forward to this one though
Been very ill for a week now after useing it on the planking for the rockerbox covers on the spitfire
Thanks for the offer Garry i will try again today, i would like to get in touch with DEPRON FOAM the people that Tony uses as they seem to be about 30 pence a sheet cheaper than Steve Webb but cannot contact them so if anyone has a phone number for them, please
