THE SECOND SR 71
11 Jun 2015 09:26 #61 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic THE SECOND SR 71
Actuly i think it is denser than the grey
But it is of no matter as i have binned the bloody thing
I did not like working with depron AT ALL
So i have 18 sheets of aero 3mm depron and 20 sheets of 6mm to throw away as nobody here uses itand i dont want it
28 Jun 2015 01:22 - 28 Jun 2015 11:04 #62 by one tenor
Replied by one tenor on topic THE SECOND SR 71
THE BLACKBIRD wrote: Iv been cynoed, i found some new industrial stength cyno and as my BSI odourless had run out ( have to use odourless as cyno kills me but at $23 for two oz i use it spareingly ) i got some and tried it
Been very ill for a week now after useing it on the planking for the rockerbox covers on the spitfire :sick: :sick: :sick: :sick:
Thanks for the offer Garry i will try again today, i would like to get in touch with DEPRON FOAM the people that Tony uses as they seem to be about 30 pence a sheet cheaper than Steve Webb but cannot contact them so if anyone has a phone number for them, please
If you can find the right thread on the 3 M site there is a glue like /Cyano ( could be a modified Cyano ) which maybe a 2 part one. If you were to contact them I am sure they could advise Loctite do a rubberised instant glue However the container is rubbis. It is rigid with two push in sections on the sides which you squeeze to dispense the glue. OK all fine so far but if all the contents are not used fairly quickly the remainder thickens and won't run to the nozzle/ I complained about this and was sent a replacement bottle. And guess what. Yes exactly the same bottle I don't know if contacting will do any good but these bottles need changing to an all flexible tube like a toothpaste tube. Try 3M#s I think it was called an adhesives forum.
Last edit: 28 Jun 2015 11:04 by .
28 Jun 2015 14:08 - 28 Jun 2015 17:25 #63 by old fart
Replied by old fart on topic THE SECOND SR 71
I hate the stuff, I only use it for furry hinges and NEVER for building.
Last edit: 28 Jun 2015 17:25 by .
28 Jun 2015 16:56 - 28 Jun 2015 17:01 #64 by THE BLACKBIRD
Actually I usually use the Bob Smith Industries one or BSI as it's know I get it from HK it is the odourless one comes in several size bottles I use the 2oz thick and thin, very good stuff far better than the Deluxe BUT it's $23 a throw, I had run out of it and tried some from the local DIY shop industrial strength and by god did it nail me, never again, although I still have a couple of bottles, Hmmmm I wonder if I leave the tops off in the kids rooms :evil: :evil: :evil: :evil: :evil:
I use it a lot, because I CRASH A LOT :S :)
Last edit: 28 Jun 2015 17:01 by THE BLACKBIRD.
28 Jun 2015 17:44 #65 by old fart
.......because I CRASH A LOT
I haven't crashed for over three years. B)
maybe it's because I haven't flown for over three years. :blush: :( :(
28 Jun 2015 20:55 #66 by Eric
Replied by Eric on topic THE SECOND SR 71
I have, once, but it was a structural failure in flight. (probably too many 'G's!) I've had a couple of near-misses when a servo failed in flight.
I HATE those furry hinges, always remove and discard them, and use proper nylon ones with a steel pin in the pivot - and I pin them in!
I've seen too many control surfaces fall off, when the builder has used those furry things, and been a bit mean with the cyano, (i.e. ARTF) so the hairs have stuck, but the hinge itself hasn't.
And - of course - cyano will not stick to cyano, so you can't re-glue them!
19 Jul 2015 13:29 #67 by one tenor
What a shame and a pity you can' t get it to N. Wales I would have bought it from you You were doing so well too
19 Jul 2015 15:14 #68 by THE BLACKBIRD
It cost more to transport it than it did to buy it :S i still have it
As for the SR71 its still unfinished business for me, two attempts nothing flown
Next one in balsa / ply with a turbine ;) :)
Time to create page: 0.214 seconds
