- Thank you received: 10727
vacuum forming
as you may have seen, i have been making a blue foam canopy for the sea hawk.
some one asked why i was not moulding a clear version, so here we go.
blue foam will not lend itself to having hot plastic draped over it, so i will have to make a heat resistant plug instead.
to save carving another one from balsa i am going to try making a mould and then casting a plaster version complete with glazing frames.
My daughter had some latex liquid left from making models, so i thought i would have a bash at making a latex mould.
first job is to clean up the plug surface and place it on a solid surface.
then you just paint the liquid latex over thee plug and onto the flat surface, this is to create a flange for mounting the mould later on.
i will need to build up about 10 layers of latex to make a strong enough mould to take the plaster.
lets hope it works ok.
then i will have to build a vacuum former for the next stage.
blue foam is so much easier to work for making plugs than wood or filler.
i hope to be able to do this with all my models from now on, even things like nose cones and engine cowls.
for the vacuum former i am thinking of having two boxes side by side, one to hold the heater and the other to use the vacuum.
then have a flip over frame to hold the plastic.
heat it over one box and then flip it over to be moulded.
might work? more likely no knowing my luck
- kamco kid
- has anyone found my marbles?
Check out youtube mate. Lots of ideas on there. Your idea is featured on quite a few of them ( as is the 'oven plunge' method that I'm currently using.) Was thinking the same way as you but not got a suitable heating element yet.Tony B wrote:
Rich
- Ralpharr2001
- Thank you received: 1476
- Skydanz
- Senior Member
I've been using my home made vacu-forming box for many years. It's takes some practice to know when the plastic is soft enough. I started out using the sheet frame in the oven which works quite well. I also found I could heat the plastic just fine over an electric stove. I made my vacuum box from some pine and used perforated sheet metal for the platform. The sheet metal is more expensive than peg board but produces much better results. More holes reduces the webbing.
Sent from my SM-G925P using Tapatalk
The sky is not the limit... the ground is!
- Skydanz
- Senior Member
- Skydanz
- Senior Member
- Skydanz
- Senior Member
i will look out for some perforated metal sheet.
- kamco kid
All the joints of the box are sealed with silicone bathroom sealant.
Hmmm, think the picture filesize might have been too big. wouldn't insert or even add to the post as an attachment.
Rich
