60" A4b for vertical take off
The tail section is first.
The biggest former is 7" in diameter.
The problem is as the diameter increases each former has to be made 'deeper' for the fuselage to maintain adequate 'handling' strength. This adds weight. For this large diameter former the inner Depron flange is replaced with a thin narrow balsa strip.
A bit of a faff to do but it is actually slightly lighter for the same stiffness than one using just Depron.
The other change, apart from its size, is to arrange the cheat holes specifically for maximum static airflow at the cost of slightly higher drag when in flight - but as a vertical riser it will not be short of 'flight' thrust.
The next stage is to build the fuselage centre section so 8 big 'ring' formers to make.
The first 3.
Each is made up of quadrants so that's 32 to be cut out (in 3 different sizes!) but by far the trickiest job is adding the balsa strip around the inside edge of each completed 'ring'.
To improve access the intent is to arrange that the wing can be slid into position after the whole fuselage is complete.
The first two formers of the fuselage centre section.
The four planks are splayed out because when the are 'curved' to match the fuselage radius they become like that.
They will be drawn back into shape as the 'stack' of formers progresses upwards - honestly!
So onto the MkII
Now in 'one piece' and with 40% more 'vane' area in the EDF exhaust.
It is made up of two layers of 2mm Depron with a balsa leading edge. Each layer is sanded on its inside to give the required section (to a very fine trailing edge) before being glued together so the outer smooth skin of the Depron is retained over the whole area.
Now just got to make the other three!
It was not easy to take this picture. The tail section had to be suspended so the free moving surfaces hung down correctly.
A bit of cardboard tube in place of the fuselage confirmed that like the smaller A4b I will struggle to get the CofG in the right place even with the 1800mAh 4s battery right forward. This really means the four servos will have to go further forward than the CofG position which in turn probably suggests I will ave to alter the way the fuselage is constructed!
I shall have to think about it carefully first.
