- Thank you received: 1476
Episode F3a
- Ralpharr2001
The fuse is composite moulded with built up wings and tailplane. The only thing in the fuse is a couple of formers so all the fitting out has to be from scratch which includes making most of the bits. Well not strictly true there are some laser cut ply parts.
The motor is a Hacker Q80 - 13S with a ZTW programmable with data logger 120A opto ESC. I am using Spektrum HV servos. Batteries will be Zippy Compact 5S 5000 mAh with 2 in parallel to give 10S.
- Ralpharr2001
The motor design I liked with was by a German F3a competitor. A bit more complex than normal motor mounts but by using shim washers it is possible to set down and side thrust very accurately.
However, he only made them to fit 85mm and 83mm diameter noses. So I copied the design and made my own to fit the Episodes 70mm nose. The shim washers are from Model Fixings.
- Squirrelnet
- Thank you received: 2067
Chris
nice bit of work with the motor mount.
i shall enjoy watching your exploits.
- Ralpharr2001
Yes it is to trim the model to fly to suit the pilots preferences. I tend to fly with a little bit of back stick on the elevator (bad habit!!) so I trim the model to have a little rearward CofG. So on inverted uplines the plane tracks straight. Its all about accuracy in a set manoeuvre and constant speed throughout the schedule.
The wings have variable incidence so you can adjust the wing incidence again to set the plane up how you like to fly. The latest models have tail plane incidence adjusters as well.
The motor is not favoured by most of the top pilots as they fly contra prop systems to eliminate the torque transmitted to the airframe. They use an inrunner onto a gearbox, look up Brenner contra unit. I don't run one because its way more than I am capable of flying and secondly I can't afford one, £1500 new, £750 second hand plus props at £160 a pair!!!
- boz
- Thank you received: 1420
- Squirrelnet
- Thank you received: 10722
- Ralpharr2001
- Ralpharr2001
- Ralpharr2001
To get the fuselage shape of the rear motor mount supports that are epoxied into the nose I used a bit of solder and pushed it into the shape of the cheek. Then used that as the outline to make a paper template and then trimmed that to suit. Marked the glass sheet, cut and epoxied with Hysol into place.
Then I fitted the rear motor mount into place and hey presto engine is mounted. The rear motor mount has horizontal slots and the cheek supports have vertical slots to give maximum adjustment. Then I made up the receiver tray and epoxied that into place.
The CofG is adjusted by moving the batteries around. To get the battery tray in the right position I used a Vanessa CofG rig.
- Ralpharr2001
Fitted the battery tray.
Made the rudder servo mount and fitted that.
Bolted the undercarriage on, nice sweep back makes its look sleek.
- Nigel
- Thank you received: 405
Can I ask, how do you ensure compatibility between fuselage material (glass with resin?) with your epoixy board (is it?) and the epoxy glue? What is Hysol? The cheap 'glass' fuselages I've had experience with didn't stick well to (fast) epoxy.
Thanks
Nigel
