- Thank you received: 10722
Episode F3a
- Ralpharr2001
- Thank you received: 1476
Maiden was exciting!! No trim required on rudder or aileron but very bad nose down attitude even with full up trim so much so at one time i didn't think it was going to come back in one piece.
Fortunately I had my friends who also fly F3a (Masters level) with me and we reset the elevator trims, moved the c of g back adjusted the rates and expo. 2nd flight awesome
Overall, very lucky first flight close to binning it and if someone had offered me a tenner for it after I had landed I would most probably have taken it!!
I will keep you posted on how the trimming out goes. Overall she's a keeper.
bet you are well chuffed now.
Tony (pranger) B
I went to the local(ish) model shop on Friday, to get some carbon tubes for making wing joiners. He'd got ONE tube, and one bar that was a rattly fit in it, then a load of those little splinters for use in holding indoor shockie ceiling tiles into shape.
Grr! Plenty of foam instant models, of course, or those multi-bladed strimmer things that sound like angry wasps nests.
It is no wonder that model-building is dying out - you can't get the flaming materials!
Just my observation, I could be completely wrong!
- mikerieder
- New Member
- Thank you received: 8
- Ralpharr2001
The rear motor support is from 3mm glass fibre sheet from:
www.hobbyplastic.co.uk/index.php?main_pa...ds578c4efmgohkjjtrg0
I turned a rear bearing insert up from a piece of ally bar I had laying around. I can knock you up one if you are stuck. The rear bearing came with the motor. I can measure it if you are stuck. Model Fixing will probably have one that fits. The OD is the important bit. The bore can be anything as you can make the support insert to suit.
- mikerieder
- New Member
Just got some glass matting and sheets to start the rebuild. I also got the hysol and a gun so hopefully can get a good bond this time.
- Ralpharr2001
- mikerieder
- New Member
- Ralpharr2001
As most of you know I entered my first F3A competition (Clubmans class) which was also my first Nationals! Nothing like getting in at the deep end!!
It worked out OK in the end and a very steep learning curve. Really enjoyed the whole event and experience.
I was having orientation problems at the Nationals (well thats my excuse!!) so added some bright yellow trim to the underside of the wings.
Must have worked as I managed 2nd in Clubmans class in my next competition!
All in all a great plane and fantastic experience.
well done on your climb up the positions in flying.
1st soon then i hope.
- Squirrelnet
- Thank you received: 2067
- boz
- Thank you received: 1420
