HP115 repairs
The nose looked like this.
It now looks like this.
I think the reconstruction will have to be a bit unusual.
The front part of the fuselage was built as a half shell over the plan and when fully complete was added to the wing.
As the damage is much more severe on the RH side that half will be built over the plan and then added to the less damaged LH side.
This way there is plenty of scope for it all to go wrong or end up not quite 'true' but the saving grace is the nose plays little part in the plane's overall aerodynamics so it should still fly.
My aim is to get it complete for the Ashbourne Scale day on the 8th October.
- boz
- Thank you received: 1420
- Thank you received: 14305
The keel planks are temporary and will be removed once the shell is lifted from the plan.
At the same time I will take the opportunity to revise the battery position and hatch as after it was painted (the great majority of the paint is behind the CofG) it tended to fly a touch tail heavy.
It was ok in super calm conditions but almost certainly contributed to its crash as the wind was the strongest I had ever flown it in!
The hatch will also lock it down.
This type is battery installation keeps it very secure with very little extra weight but it can be an issue if it swells!
All the skin is now complete.
The nose cone is made from of a stack of 8 laminate underlay 'rings'. It is similar to lightweight 'aero' Depron.
A bit of a faff to do but being so far in front of the CofG (36" or 90 mm) every extra gram has a big effect.
And it flies!
The only mistake was I made the battery box a snug fit for an 1800mAh 3s only to find the one I used has slightly different dimensions (by less than 1 mm!) to the other two I have.
Although the latest crash looks relatively modest by comparison.
As is the way it tends to end up a more complex job.
Where the RH elevon was ripped away it crushed a portion of the wing tip which had to be significantly cut back so will need a part rebuilding.
A bit nearer the nose the wing leading edge was similarly crushed and will require the same sort of treatment.
The rest of the dings and dents (9 more!) should be simple(?) 'patch' repairs.
Thinking about the difficulty I had controlling the flight I noted that during the control checks the 'stab' function was working but it did not switch 'off' regardless of which switch was tried.
In hindsight I should have deduced something was wrong as on previous flights the 'stability' effect was dramatic when it was 'on'.
This does rather suggest that the crash was more the result of the stab not working properly than just the weather conditions but either way it is still down to "pilot error".
