DH 91 Albatross
First a 3 view.
An elegant design but with some features that could raise issues in a model.
The fins extend well below the tail plane so would be likely to strike the ground in an 'untidy' landing.
The elliptical wing might pose some stall issues unless some washout is included.
On the plus side
The single main wheel is a relatively big diameter although the one piece folding U/C door would be a bit of a challenge!
Scale ailerons are fairly generous as is the prop ground clearance.
The next big question is what size to make it?
By measurement from the 3 view the prop diameter to wingspan has a ratio 1:10.95
So a 6" prop will give a wing span of 65.7", a 7" prop 76.7", a 8" prop 87.6" etc
I had originally thought of using a 9x6, as it is a good match for a cheap 1200kV 150W out runner, but at 98.6" span the Albatross would be a good bit bigger than I would like.
"I think I had better think it out again!"
- boz
- Thank you received: 1420
- Squirrelnet
- Thank you received: 2067
- Mike Rolls
- Thank you received: 573
Rather small for a multi so everything will have to be really light but a 6" prop is quite a popular size in small racing drones and there are quad motor/prop/ESC deals on Ebay!
Although strictly not scale, the full size was all CW, on a small(ish) super light RC plane eliminating motor torque is no bad thing.
A bit of internet searching is called for.
BTW this comes with a pair of opposing props O/Tone tenor wrote:
Quorneng wrote: As I hinted to in the Cafe this could be quite a long build process.
First a 3 view.
On the plus side
As I have posted elsewhere on the forum robotbirds are doing some good motors at very reasonable prices.
www.robotbirds.co.uk/default/mt2213-935-...combo-cw-thread.html
is the one I bought recently but there are loads more with loads more makes. Have a squizz for yourself. Just Google Robotbirds and go to motors... Nice Idea go for it.
In 1943 he joined Airspeed as technical director and was responsible for the design of the Airspeed Ambassador which shared some 'family' resemblances to the DH 91.
Quorneng wrote: The design of the DH 91 is credited to A E Hagg who rose to become Chief Designer from an Airco draughtsman in 1916. He also designed the DH 86 Express (A DH Rapide with 4 engines). He left DH in 1937 so had no direct influence on the design oft the Mosquito.
You're right I recall the ambassador from when I was a nipper Never seen a DH86 Express . Were many made.?Thanks for the info.O/T
Fast and efficient however it did not have a particularly good safely record being difficult to handle in adverse conditions. After three fatal total loss crashes in Europe an A&AEE report concluded the plane had significant stability issues which were largely cured by adding additional fins to the tail plane. It appears these mods were never communicated to the Australian users where its poor safety record continued. None remain.
The Ambassafor (Elizabethan in BEA service) is forever remembered for the 1958 Munich air disaster which killed 23 including 8 members of the Manchester United football squad and 3 coaching staff. The publicity around the crash hastened the withdrawal of the type in favour of Viscounts.
First job is to workout the pitch of the mounting bolts and the size of the aperture for the wires.
Most of the DH Albatross nacelle is virtually circular so it seems logical to 3D print it. After a bit of experimentation it should be possible to do it as a single piece.
The 28 mm diam motor bell is a very close fit within the nacelle.
Bolted from the rear.
The bare nacelle weighs just under 6 g.
It will need a 30 mm spinner.
- Mike Rolls
The cowls you've made look really good, but for a competition scale model the finish would have to be a lot smoother. Can the 3D prints you've produced be sanded or turned to produce a smooth finish?
You've probably guessed that I have a vested interest in the answer...
the finer the layers the smoother the print but the longer thee print time.
