Precedent T180 Restoration
- squareflux
- Thank you received: 328
One thing I'm finding difficult, but enjoyable, is working out the order to build in. I suppose with a kit, there'd be a list of instructions on the order to follow. I find myself stopping to go off and think about it, before doing the next step.
Just now I'm thinking about whether to do the top sheeting or the ends first.
I've got the bug for scratch building though
- squareflux
- Thank you received: 10722
- squareflux
- squareflux
I have some snake exits to use, but there was no guide on how to attach them. Has anyone used these? I take it they go on the outside surface, but what's the best way to attach them?
They are supposed to reduce drag, but in reality they just make a ragged hole look tidy! You still have to secure the snake outers so it can't slide about.
Epoxied into the deck
Sanding still to be completed, just to show the general idea, the snake is glued to the formers on the inside.
- squareflux
It seems easier to do it the way you have rather than try and attach the exits I bought.
- squareflux
They're going through a former halfway along the fuselage. Then I'll glue the snake outer inside the exit cover, and glue the exit onto the skin.
There's a bit of a gap to the furthest rear former to glue them to, and don't want to bend them to reach it.
Geometry suggests it does not matter what the snake does between its fixed end points as the inner has to do exactly the same so there is no differential movement between them.
The biggest issue is the length of the inner free ends. No problem when pulling but when pushing the inner (it is quite flexible by design) can bow so limiting the force generated at the control horn.
A test. If you hold the control surface rigid can the snake withstand the servo stall torque. I bet it can when pulling but less likely when the servo is pushing.
Like Indiana Jones I am not keen on snakes.
