A bigger DH Venom
Fortunately being made up from two ellipses in FreeCad it only required a single dimension, the max diameter, to be changed to give a new fatter shape.
Obviously it uses a bit more material so the weight goes up from 2.9g to 5.3g.
- jon.in.swansea
- Thank you received: 1164
The wing is not quite as thin as it might look. In fact the aileron servo position was chose so the tiny 3.7g servo would just fit between the skins.
The underside skin was locally cut away to allow the servo to be inserted and glued to the underside of the upper skin. The servo was then covered with a Depron panel sanded to a variable thickness so the under side of the wing was flush.
My usual glued in totally inaccessible servo installation.
A short video on the aileron working.
All the surface horns are identical although the very short elevator link does result in the elevator having slightly different travel.
- jon.in.swansea
Putting servos in places where it can't be accessed for adjusting the arm without getting an X-acto blade is
something that has caught me out a few times. My older Dragonfly I discover has one of the inside-the-wing servos flapping
around because it broke its bond to the wing. Argh.
So far my glued in servos, in most cases they are glued to both the upper and lower skins, have never "let go" other than in a serious crash where the wing damage was such that the servo would have to have been reinstalled anyway.
I have been thinking about a colour scheme for the Bigger Venom. The Swiss Airforce continued to use Venoms long after the RAF and even had an aerobatic display team of garishly decorated Venoms.
My scheme will be based on one. Very simple bright red and white which also matches the Swiss air force markings. Scarlet red fuselage, wing roots, booms, fins and tip tanks. Outer wings and tail plane white.
Should be easy enough to see.
- jon.in.swansea
Hot-melt is thermally unstable ie - if it gets warm, it creeps!
I've told the tale - previously - that in my slope-soaring days, one of the gang built a wood model bonded entirely with the 'new' (at the time) hot-melt. He was expounding on how fantastic it was, and how quickly the kit model went together until he noticed that it was going droopy in the sunlight!
A 3.7g servo 'as supplied' next to a 'glued in' servo extracted from a wing due to a stripped gear.
Even the mounting lugs have been cut off which means I have lots and lots of the tiny mounting screws spare!
