Folland Gnat 50mm EDF
23 Jun 2026 12:05 #1
Folland Gnat 50mm EDF was created by Quorneng
Although I built it in 2009! it appears I never described it on this site at the time or so the search engine says!
It was about my first EDF to use a printed duct and followed my preferred "EDF at the back layout".
In addition its 8 blade EDF was sized to match the inlet area available from the scale inlets which meant using a relatively small EDF.
As a result the airframe had to very light being made almost exclusively from 2mm sheet Depron.
The long duct was used as a "spine" to support the fuselage formers.
Slowly it was planked in 2mm Depron. It was also my first to use solid "magnet" wire ESC to motor to save weight rather than conventional silicone insulated multi strand wire.
The scale thickness anhedral wing was skinned in 2mm Depron.
and used a wood/Depron/wood box spar.
As I reported in Mach this year it suffered a serious nose plant!
Atlast today it is all back together.
Any test flying will have to wait for some seriously calm weather.
On a scale note I built it with a fixed tailplane and elevators. On another web site it was pointed out the Gnat used a power assisted all moving tailplane. What I took to be the elevators were actually just trim tabs on the full size.
A further point was there was no hydraulic back up for the tailplane. If the hydraulics failed you had to disconnect it and fly using just the manual trim tabs as elevators. It worked but was considered far from ideal in a military aircraft particularly for low level flying. Perhaps no one told the Red Arrows!
When HAL in India built the Gnat under licence the first thing they did was to duplicate the tailplane hydraulic system!
Incidentally the lead designer for the Gnat was W E W Petter. His other design work included the Westland Lysander, English Electric Canberra & Lightning before he moved to Folland.
Quite a record!
Quite a record!
23 Jun 2026 16:21 - 23 Jun 2026 16:56 #2
Replied by Eric on topic Folland Gnat 50mm EDF
I remember seeing you building the Gnat, so perhaps it has changed titles along the way, which is why 'search' can't find it.
It gets a brief mention here - 13 May 2026 22:
After some hunting, I found it - Folland Gnat T1 January 03, 2020!
Last edit: 23 Jun 2026 16:56 by Eric. Reason: added a comment
26 Jun 2026 13:13 - 26 Jun 2026 13:13 #3
Replied by Quorneng on topic Folland Gnat 50mm EDF
It appears I missed the default 1 year search period!
I also notice in the build blog I posted "I will fit the QX50 with its 12 blade fan once the repairs on the Skray are complete". Well I never did!
It actually went into the Hawker Hunter F6 which was my first EDF to have a QX50 which explains why it drains its 1800mAh 3s so quickly without strict throttle management!
Last edit: 26 Jun 2026 13:13 by Quorneng.
- jon.in.swansea
- Thank you received: 1164
29 Jun 2026 18:07 #4
by jon.in.swansea
Replied by jon.in.swansea on topic Folland Gnat 50mm EDF
Thanks for sharing the history of this model!
Time to create page: 0.209 seconds
