Radio Control Aeroplane, Radio and IC Engine
  • Fghhhgfggg
  • New Member
  • New Member
01 Feb 2022 01:12 #1 by Fghhhgfggg
I have for sale the Mini Jazz designed by Malcolm Corbin which has been finished to a very high standard, covered with Profilm and fitted with a Carbon Copy undercarriage. The canopy and cowl need fitting, together with the elevator pushrod to complete this model.
NEW OS 15LA is fitted which has never been used.
NEW Ripmax micro servos SD200 (x5) and Rx battery pack are fitted into the airframe.
Futaba T6X field force 6 transmitter (Ripmax 50th special anniversary edition) fitted with NEW Nicad battery pack.
Rechargeable Glo start, rx battery checker and hand fuel pump.
All plans and manuals together with various modelling hardware will be included with sale.
I would like £85 for everything which can be viewed at Herne Bay, Kent.
Please PM me if you are interested and would like more details and photos.
01 Feb 2022 06:52 - 01 Feb 2022 07:37 #2 by Klipkopwildlife
Replied by Klipkopwildlife on topic Radio Control Aeroplane, Radio and IC Engine
Very nicely put Allan, everything anyone needs to know and what seems to be a very good price. If I lived in the UK I'd be knocking on your door.
I did a bit of looking up, the Mini Jazz was the RCM&E mass build of 2014. A 47" low wing it's not for beginners. The planned wing loading was 18oz/ft2. Most of them came out at around 16oz. What I found interesting was the sealed aileron gaps which apparently transformed the low speed handling.
Last edit: 01 Feb 2022 07:37 by Klipkopwildlife.
Thanks: Flytilbroke, Quorneng, THE BLACKBIRD, Fghhhgfggg
  • Fghhhgfggg
  • New Member
  • New Member
02 Feb 2022 00:53 #3 by Fghhhgfggg
Replied by Fghhhgfggg on topic Radio Control Aeroplane, Radio and IC Engine
Yes the Mini Jazz was indeed a RMCE pull out plan but luckily I purchased a latter copy from Nexus Plans Service which had the correct tailplane angle shown of zero degrees and not the 3 degrees that was shown on magazine version.
The build was very enjoyable and at 34" wingspan will fit into the back of even the smallest car and fly off a small area.
While i'm waiting on the sale, I have started to assemble the split elevator control rods so that will only leave the fitting of the cowl and canopy for the new owner to complete.
02 Feb 2022 07:11 #4 by Klipkopwildlife
Sorry, I can't find where I got 47", my bad. 34.5" it is. With the very broad chord it reminds me of the C/L stunters we used to build.
  • Fghhhgfggg
  • New Member
  • New Member
06 Feb 2022 18:19 - 06 Feb 2022 18:27 #5 by Fghhhgfggg
I have now installed the split elevator control rods and connected to the servo so all that’s left to complete is the fitting of canopy and cowl.
I have added photos of everything included in this sale and reduced the price from £85 down to £65.
Last edit: 06 Feb 2022 18:27 by Fghhhgfggg.
  • Fghhhgfggg
  • New Member
  • New Member
07 Feb 2022 02:46 #6 by Fghhhgfggg
Now ****SOLD****
Thank you
07 Feb 2022 07:10 #7 by Klipkopwildlife
Thanks for the 'heads up' looks to have been very nicely done, however I do hope the new owner doesn't try and fly it with that 35meg aerial coiled up on top of the fin!
Time to create page: 0.148 seconds
