Why I've Started This Category.
  • Phil Wood
  • Inactivated User
  • Inactivated User
03 Feb 2012 20:16 - 03 Feb 2012 20:39 #1 by Phil Wood
Why I've Started This Category. was created by Phil Wood
Some of us have started to use the Phoenix flight simulator in group sessions on line, myself being one.
It seems popular so I thought it deserved a thread dedicated to the actual program.
I've only just started using it and at first I thought I could see some things that would put me off.... a simple example is that having trimmed a model to glide, I then found that as soon as I put on the power it would climb at a stupid rate..... I didn't realize that I could then add down thrust as I would do if it were a real model.
Some users don't even know how they can go into spectator mode and then select which model they want the camera to follow.
I'd like to use this thread to discuss all the intricacies that we find & help each other get the best from the program.
Please use the “e-flying club” thread for any idle chit chat about the group sessions, keep this one strictly for how to get the best from the simulator.
We can use the help facility for most needs, but let's be honest, who ever bothers with that?
Last edit: 03 Feb 2012 20:39 by Phil Wood.
03 Feb 2012 20:24 #2 by Eric
Replied by Eric on topic Re: Why I've Started This Category.
When you have opened phoenix, click on model - edit - detailed - and you can move the c of g, model size, aerofoil section, and lots more. Have a play.
  • Phil Wood
  • Inactivated User
  • Inactivated User
03 Feb 2012 21:12 #3 by Phil Wood
Replied by Phil Wood on topic Re: Why I've Started This Category.
Eric wrote: When you have opened phoenix, click on model - edit - detailed - and you can move the c of g, model size, aerofoil section, and lots more. Have a play.
I think you know the program better than I do Eric ... you can take over from here. :lol:
If anyone finds something about a particular model then please start a new thread for that model... a bit like I've done for the Cessna 182.
We may end up with a lot of threads but it should make it easier to find a particular alteration for each model.
03 Feb 2012 22:06 #4 by Eric
On the phoenix flight pics. Along the top are various headers that pop up when you move your mouse cursor up. Most of them are self-explanatory.
System - sets up or switches between your different trannies. (No not transvestites, Pol!)
Model - sets up which model you are flying, and in there you can tweak settings.
Flying site. - changes site, but you can also dial up the weather, wind, thermals, gusts, etc.
View - in here you can choose camera, which is where you are looking, etc, displays, which puts dials on your flying screen, showing various things as per the sub-headings in there. When you have a dial on your screen, you can move it to a different location by putting your mouse cursor on it, holding down the left-clicker, and dragging the dial to where you want it.
Flight Recorder - pretty obvious what that does!
Training - again self-explanatory - mostly for helithrashers.
Competition - different challenges for you to try. (or not, if you prefer!)
Multi-player - puts you on-line. Fill in the box with 'A' name - (doesn't have to be yours!) then you can choose to start your own site, or join someone else's from the list. Drag the bar down until you find one, left-click it, then left-click the box at the bottom that says join site.
If you have a mike and speakers/headphones, you can chatter with the others on there while you fly/spectate. OR you can type messages, just like in our chat-room. below the comments at the bottom, left-click in the very bottom line, type your words, and hit 'enter' to post it.
  • Phil Wood
  • Inactivated User
  • Inactivated User
03 Feb 2012 22:24 #5 by Phil Wood
If we make adjustments to a model e.g. down thrust .... can we save those settings for the next time we use that model?
I did manage to come accross a "default" button somewhere, which changed the default model that I start with .... buggered if I can find it now!
03 Feb 2012 22:33 #6 by Eric
I think so. I didn't use that function much, but I think when you make changes, it 'saves' the new model as copy 1, copy 2 etc, so you can choose which one you want. The change is only on your computer, though, not on the mainframe, so nobody else can access your mods.
  • Phil Wood
  • Inactivated User
  • Inactivated User
03 Feb 2012 22:40 #7 by Phil Wood
It must be just on this computer because you don't sign in until you go on line .... I just don't want to keep making the changes every time I log on. :(
03 Feb 2012 22:49 - 03 Feb 2012 22:57 #8 by Eric
If you set up the changes BEFORE you go on-line, I think the settings are saved, so when you go online, you can select the altered one, or the original.
Default undos all your changes, and puts the model back to original settings.
Last edit: 03 Feb 2012 22:57 by Eric.
  • Phil Wood
  • Inactivated User
  • Inactivated User
03 Feb 2012 22:58 #9 by Phil Wood
Eric wrote: If you set up the changes BEFORE you go on-line, I think the settings are saved, so when you go online, you can select the altered one, or the original.
I can make the changes off line & then take that model into any on line site that will have me . :whistle: .... that's why I don't get much flying done. :unsure:
I just want to switch on the next day & find my changes saved.
Time to create page: 0.248 seconds
