× For those of you with deep enough pockets
GIANT SCALE T-27 Tucano Turboprop [4K]
  • DominicM
  • DominicM's Avatar Topic Author
  • Vlogger for 'Essential RC'
30 Dec 2016 08:23 #1 by DominicM
GIANT SCALE T-27 Tucano Turboprop [4K] was created by DominicM
Interesting fact I wasn't aware of is that there is no physical connection (i.e. no shaft) from the engine to the prop. The efflux from the turbine exhaust spins an impeller connected to the prop. Very efficient apparently and results in up to 50lbs of thrust just from a 60 size engine. Also sounds amazing.
www.youtube.com/c/essentialRC
Thanks: boz, Kintosh
30 Dec 2016 10:13 #2 by Eric
Replied by Eric on topic GIANT SCALE T-27 Tucano Turboprop [4K]
It's probably my graphics card, but it won't go any higher than 1080P hd, and it makes the sky very smeary and pixellated, at times.
Nice Tucano, though. As there's not much compression, it must be a swine to flick-start! :-) [badass]
  • DominicM
30 Dec 2016 14:38 #3 by DominicM
Replied by DominicM on topic GIANT SCALE T-27 Tucano Turboprop [4K]
Zero compression! None what so ever. You could hold the prop while it starts and it wouldn't move...although would burn the compressor nicely (so the owner told me).
30 Dec 2016 15:19 #4 by Quorneng
Replied by Quorneng on topic GIANT SCALE T-27 Tucano Turboprop [4K]
Its a free shaft turbo prop or turboshaft for short.
Very neat but strictly not to scale as the RAF Tucano used the Garrett TPE331 which is a true turboprop i.e. the prop is connected directly to the turbine. ;)
Thanks: Eric, DominicM, boz
  • DominicM
30 Dec 2016 22:22 #5 by DominicM
So is the turboshaft setup used in any full size aircraft?
30 Dec 2016 23:24 #6 by Quorneng
Dominic
Actually original Embraer Tucano does use a turbo shaft, the P&W PT6, but not the RAF version that was built by Shorts. :P
The PT6 is very widely used in many 'bigger' light aircraft.
Virtually all helicopters use a turbo shaft. You would never get the turbine up to self sustain speed if the starter motor had to drive the rotors as well.
Thanks: DominicM, boz
  • DominicM
31 Dec 2016 07:29 #7 by DominicM
Here's another flight I caught. Very late afternoon. Almost dusk. But showed off the light system to maximum affect.
Thanks: Quorneng, blue123, boz, Kintosh
Time to create page: 0.138 seconds
