Best Essential RC FPV Onboard clips
- DominicM
- Vlogger for 'Essential RC'
www.youtube.com/c/essentialRC
- Thank you received: 14191
I can't find the item I wanted, but a guy who uses 3D says a 14 minute vid took 22 hours to load up, due to the file size.
poster - Tomorrows 360° virtual reality video is being published in the morning. It took 22 hours to upload to Youtube.
reply - Ouch 22 hours that took a while mate
poster - 14GB in size mate
- DominicM
- DominicM
- DominicM
- DominicM
This camera allows you the viewer to change the field of view both horizontally and vertically by using your pointer. Pan to the rear of the jet to see it climb out steeply or pan to the front to scorch across the strip. Enjoy !
- Flytilbroke
- Thank you received: 1972
- DominicM
Use your pointer to change the view as you watch !
- Flytilbroke
As FTB noted - you can zoom in too, use the scroll wheel.
That slot you can see is the glider tow-line release - though how you get an (optional) servo in there - - -
Also - as I've found out - if you hear a sharp click as the prop starts to turn, take the prop and cowl off, (four screws) remove the motor X-mount, and check that the little 2.5 x 5mm countersunk screws that hold the motor to the mount haven't worked loose. I've lost six of them so far! (and put bits of blenderm tape over them, now, to try to stop them escaping!).
