charging small nimh packs
got a problem, not got a suitable charger, I do however have a larger charger ( 6v-1000mah) which will obviously cook them.
Someone care to tell me if I'm talking sphericals but if I put a 250 ohm resistor in parallel it'll bring the output down to 23mah? (Nice slow charge)
it's years since I did any electronics and I may have got the formula totally wrong........
You'll get a VERY hot resistor! Work out how many watt you will be dumping through it! You would also need to put a diode between the resistor and the cell-pack, or it could discharge thorugh the R if you weren't careful
Perhaps you meant series?
How many cells in the pack? A 6v input might just be enough volts to charge a four-cell.
It's a long time since I tried charging a nimh, but If I recall, they don't like a constant current charge, and you need some way of measuring end voltage, so the input tapers off as it is reached.
A proper nimh charger is only a couple of quid on fleabay.
Oh 4 cell obviously.
For a 2000mAh (AA cell?) 1/300C would be just 6.6 mA.
Interesting factoid.
The patent for NiMh technology was bought by General Motors in 1994 and the first generation electric vehicles used it until pressure from the petrochemical industry caused their withdrawal in the late 90s and just to ensure NiMh batteries did not come back in this application the patent was sold to Texaco in 2000.
A normal Futaba (etc) 4 cell flight pack charges ar 50 mah x 14 hrs
care to give me a simple circuit diagram?? in series= across the +/-?
