Reducing servo throw
07 Jan 2012 18:48 - 07 Jan 2012 18:49 #1 by Klipkopwildlife
Reducing servo throw was created by Klipkopwildlife
Here's the problem, I have a Futaba T9CP. This is a 9 channel computer radio. All channels are proportional, except the 9th! Which is either on or off. A gadjet that I have requires pulses of 900microseconds for its Off state and 1500microseconds for its On state. When switched, channel 9 gives me 900 and 2100. From within the radio channels 1 - 8 can be trimmed, end points adjusted reversed etc. You can only reverse channel 9, nothing else!
I need all 9 channels!
Anybody any ideas? Is there an after market product that I can use?
Last edit: 07 Jan 2012 18:49 by Klipkopwildlife.
07 Jan 2012 18:57 #2 by Eric
Replied by Eric on topic Re: Reducing servo throw
It might be stating the obvious, Klippy, but have you tried it to see if it works?
The two ranges quoted for the gadget (you don't say what it is) might just be the switching limits, and it will happily take less and more pulsewidth.
07 Jan 2012 19:28 #3 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: Reducing servo throw
Ok, I tried to keep it simple! The object is an FY-21AP auto pilot, 900mics is off, 1500mics is Stabilized flight and 2100mics is Fixed altitude. This whole thing is running with a FPV camera and an AP117 mixer to give On Screen Display of speed, artificial horizon, altitude and a few other bits of information.
Since this aircraft is to be used for Game counting by inexperienced persons, and I expect this aircraft to be frequently Out Of Sight, Stabilised flight is quite necessary, Fixed altitude is warned against in the manual since if you lose power for any reason the FY-21AP will stall the aircraft into the ground!
07 Jan 2012 19:41 #4 by Eric
Ah - I see what the problem is, now!
Off the top of my head, i don't know of any solution - (see my PM) - so I'll shut up and see if anyone else has any ideas.
09 Jan 2012 21:39 #5 by Phil Wood
Replied by Phil Wood on topic Re: Reducing servo throw
I get the idea Klippy ... 1.5ms is servo center ... the other two figures are the end points.
You'd have to do a little modification to the Tx but it's quite easy.
On the switch you'd have to solder a couple of small resistors or a preset pot ... so that the switch will then flick between servo center & one end point.
Try to post a pic of the insides (close up of the switch) ... & I'll edit the pic to show you what's needed.
You could even change the switch for a pot & have all channels proportional. :)
09 Jan 2012 23:16 #6 by Eric
:oops: should have thought of that ! :oops:
09 Jan 2012 23:40 #7 by Klipkopwildlife
Thanks Phil, will do. I tried it on one of my 6EXs' but it didn't want to work.
10 Jan 2012 18:06 #8 by Klipkopwildlife
A few pics
That's just with the back off
Two of the switches out and turned around
Here I've released the PC board, you can see all inputs have a diode feeder.
10 Jan 2012 18:16 #9 by Klipkopwildlife
It would appear that the switches are bussed direct to the main computer, there appear to be no on board resistors, except the pots for the continuously variable channels. These are called VRa through VRe and can be assigned to channels 5 through 8, but not 9! The switches (SWa through SWg, 4 on/off and 2 off/half/full) can be assigned to channels 5 through 9. But, here's the rub, if I assign a 3 position to channels 5 through 8 I get off/half/full, but assigning a 3 position to channel 9 gives me off/full/full
10 Jan 2012 18:28 #10 by Eric
You could always email Ripmax, and explain your problem, and hope they can offer a solution.
10 Jan 2012 18:59 #11 by Klipkopwildlife
At the moment I'm looking at the 'mixes', but the mixes don't seem to be variable. ie, you've got, flaps elevator, aileron rudder etc, nothing that's freely asignable.
11 Jan 2012 08:56 #12 by Phil Wood
Klipkopwildlife wrote: It would appear that the switches are bussed direct to the main computer, there appear to be no on board resistors, except the pots for the continuously variable channels. These are called VRa through VRe and can be assigned to channels 5 through 8, but not 9! The switches (SWa through SWg, 4 on/off and 2 off/half/full) can be assigned to channels 5 through 9. But, here's the rub, if I assign a 3 position to channels 5 through 8 I get off/half/full, but assigning a 3 position to channel 9 gives me off/full/full
Bear with me on this one Klippy, you know I'm not up to full speed after my heart op' yet but I'll give it my best shot.
The general industry accepted standard in the RC world is that a 1.5 millisecond pulse will correspond with servo dead center.
The Tx sends out a series of these pulses followed by a synchronizing pulse that re-sets the whole system. ... The number of pulses equals the number of channels on the Tx.
The Rx has a decoder that splits these pulses into the appropriate channel & sends them to the servo.
If the pulse gets shorter then the servo moves one way ... a longer pulse moves it the other way.
The radio transmitter section of the Tx will run off whatever the battery voltage is but the computer brain will probably run off a stabilized 5V line produced by a voltage regulator.
If you measure the voltages on either side of the stick pots you'll probably find 5V at one end and 0V at the other ... the center terminal will be somewhere in between depending on stick position ...... 2.5V will tell the computer chip to send a 1.5ms pulse..... "Typical potential divider".
You obviously have sufficient knowledge to look for these voltages.
It is probable (but not certain) that a nine channel set will have all channels proportional ... it's cheaper for them to photo etch an Identical channel onto a piece of silicon than it is to design a whole new chip.
On a typical set that has a retract switch you can often remove the switch & replace it with a pot thus turning it into a proportional channel. ... 0V to the comp may be retracts up & 5V may be retracts down .... in theory you could use a 3 way switch & have the center position give 2V to the comp chip & the retracts would only half extend & let you land like Garry! :lol:
There is the possibility that the encoder in your Tx is 8 channel proportional & 1 switched but God only knows why they would have done this.
Have a play around & let me know if you understand what I mean about the voltage from the center pin of the stick pot's .... I'm pretty sure you will.
Then we'll figure out if channel 9 is proportional. ;)
11 Jan 2012 12:02 #13 by Klipkopwildlife
Hi Phil, I see where you're coming from, I'll have a poke around and see what I can come up with.
11 Jan 2012 23:15 #14 by Phil Wood
The first thing to do Klippy is check if I'm correct about the voltages on the stick pot's..... 0V & 5V at either end ... the center terminal will vary according to stick position.
If this isn't the case then we may be dealing with circuitry that I'm not familiar with.
You can then check if these voltages apply on either side of the switch contacts .... the only difference should be is that there'll be no variable voltage on the output to the computer ... it'll just be switched.
Once you've found the wire that is the output to the comp you could always just disconnect this from the switch, ..... attach it to the center of one of the stick pots, & check that channel 9 is proportional.
(Disconnect the other wire first)
pol.
12 Jan 2012 23:42 #15 by Klipkopwildlife
Silly busy at the moment, later!:ohmy:
Time to create page: 0.271 seconds
