- Forum
- Forum Categories
- Technical Stuff, Radio Gear, Electronics.
- receiver switch with built in voltmeter.
06 Apr 2012 19:01 #1
receiver switch with built in voltmeter. was created by Eric
No eBay APP ID and/or Cert ID defined in Kunena configurationI got a couple of these off e-bay, to try, and suffice to say I've sent for a couple more!
They are just what you see, a proper toggle-switch with a built in voltmeter, so you can see what is left in your battery.
They are quite large, so not suitable for tiny models, but for use in the bigger ones, with a lot of servos, they would be ideal.
The casing is 1.5 inches long, 0.5 wide, and 1 inch deep.
They weigh 40 grams.
Mine are fitted with Futaba plugs.
I am waiting to hear if they will accept a higher voltage, for other purposes.
The item number - 260985793012
or go to -
or go to -
- Phil Wood
- Inactivated User
06 Apr 2012 19:15 #2
by Phil Wood
Replied by Phil Wood on topic Re: receiver switch with built in voltmeter.
They look neat Eric, a little bit pricey but if they do the job & save a model ... or a person! ... gotta be worth it.
- Dean M
- Thank you received: 326
07 Apr 2012 00:56 #3
by Dean M
I nearly choked on my latte.
Replied by Dean M on topic Re: receiver switch with built in voltmeter.
Thanks Eric they look like a good idea, when you say they only sutible for larger models would a 71" span be big enough? May invest in one for my four star 60.
Dean
Dean
07 Apr 2012 01:02 #4
by Garry Pollard
Replied by Garry Pollard on topic Re: receiver switch with built in voltmeter.
Hi Dean
I think Eric was suggesting a model of about that size, as they are quite large, and would look out of place on a little foamy
07 Apr 2012 01:04 #5
by Ex-Member
Replied by Ex-Member on topic Re: receiver switch with built in voltmeter.
no real need if you fly electric, unless you have a bec.
07 Apr 2012 03:46 #6
Replied by Eric on topic Re: receiver switch with built in voltmeter.
There's no point in having one on an eleccy model with any form of voltage dropper from the lipo! The volts are regulated by the dropper!
Dean, i put suitable for the larger model because of the size of the switch and casing, not because of the weight!
- Forum
- Forum Categories
Time to create page: 0.158 seconds
