Twinjet setup?
  • Dean M
21 Apr 2012 15:17 #1 by Dean M
Twinjet setup? was created by Dean M
I managed to gain a Multiplex Twinjet a couple of days ago, it still has the old 480 size brushed motors fitted and a 18AMP ESC, what motors would i need if i went brushless?
I have seen a few single motor conversions, what motor would be suited for this?
Would the 18A ESC be ok for the single motor setup?
From what i gather it weighs about 2 1/2 lbs so was thinking about 300W would be about right?
As you can tell I am a complete electric newbie and properbly sound like a right thicko!!!
Dean
I nearly choked on my latte.
21 Apr 2012 15:56 #2 by whis1962
Replied by whis1962 on topic Re: Twinjet setup?
Dean,
Found this on another forum:
hi
i was wonder about converting a old Multiplex Twin Jet into brushless power rather than brushed
does anyone know of a good setup for it? does anyone have one?
thanks.
hi tim,
i don't have a twinjet, but i do fly a funjet with a brushless setup. The motor, a HiModel 283635 produces up to 400 watts and runs very smoothly. it needs a 40Amp ESC on a graupner CAM speed 4.7x4.7 prop. They are very lightweight at 50 grams. This setup was recommended by Yellowred. you could use 2 of these motors but as its brushless you'll need 2 ESCs. I don't know whether you'd need one large flight pack or two smaller ones. (I use a 3s 2200 25C pack) I am sure 800 Watts max would be plently of power, but the problem might be weight.
Whis
  • Dean M
21 Apr 2012 19:52 #3 by Dean M
Replied by Dean M on topic Re: Twinjet setup?
Thanks Whis, just having a look for simular spec motors as the only place that seems to sell those himodel motors are in America
Dean
21 Apr 2012 20:07 #4 by Grumpy42
Replied by Grumpy42 on topic Re: Twinjet setup?
Dean M wrote: As you can tell I am a complete electric newbie and properbly sound like a right thicko!!!
Dean
Now hold on Dean - I am not even an electric newbie and I respectfully insist on my right to retain the title of the right thickest in that category! :lol: But given that - there are a few extremely knowledgeable blokes on this forum who are more than capable of steering you in the right direction if you insist on joining those dreadful *lectric people. I shall steadfastly maintain my other title as well - "The Dinosaur of Diesel and glow stuff!!! :P
21 Apr 2012 20:19 #5 by whis1962
Dean,
Try this link to Purple power's site for brushless inrunners;
www.4-max.co.uk/inrunners.htm
There is also the specs for each motor i.e size etc.
Steve
  • Dean M
21 Apr 2012 20:39 #6 by Dean M
I really didn't think it possible to be thicker than me on the hole electric thing so thanks Grumpy :lol:
Good website that, Whis thanks.
I reckon on 300Watts to be about right so if i had two motors would that be 150W for each?
How does the Kv rating effect the performance?
Dean
21 Apr 2012 22:34 #7 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: Twinjet setup?
The Kv rating x volts will give you the maximum rpm, tell what size props you're limited to.
22 Apr 2012 00:53 #8 by The Beard
Replied by The Beard on topic Re: Twinjet setup?
Work on 100 watts per pound weight.I converted a Twinstar to brushless.I used 2 esc and 1 battery,having put it together I gave it away and it still flies well.
  • Dean M
22 Apr 2012 01:11 #9 by Dean M
The Beard wrote: Work on 100 watts per pound weight.I converted a Twinstar to brushless.I used 2 esc and 1 battery,having put it together I gave it away and it still flies well.
Hi
Do you remember what size motors and battery you used?
Dean
22 Apr 2012 01:46 #10 by whis1962
I'd use a single 3700kv inrunner, 40esc, 4.5.x.4.5 prop to keep the weight down rather than a twin setup.
22 Apr 2012 03:05 #11 by Klipkopwildlife
A real screamer then Whis, but would have had plenty of grunt.
22 Apr 2012 03:25 #12 by whis1962
Yeh, A bit like me really.
22 Apr 2012 03:29 #13 by The Beard
No sorry to long ago,they were only small motors and esc,if I see the guy Ill find out he is a member of my club
Time to create page: 0.189 seconds
