ESC programming.
25 Oct 2012 20:21 #1 by Klipkopwildlife
ESC programming. was created by Klipkopwildlife
Had a problem the other day, I bought some ESCs' from Hobby King, I thought they were Towerpro, but when I came to program them, they refused to talk to my Futaba 6EX 2.4gig! I fiddled around a bit and failed miserably to program all 4 of them!
Then I noticed they were marked Towardpro, bloody clone industry!:( Anyway, then I tried on JR 35meg TX, and no problems?:( At Phils insistance I hooked up a scope, (first find a power pack, then a probe!) Then discover that JR used channel 1 for throttle instead of channel 3, only 30mins there! In comparing the signals, I noticed that the JR pulse went much shorter at minimum throttle, it was about then that a light went on in my brain cell! Throttle cut! You must take the trim right down as far as it will go, otherwise the ESC won't listen to you!
I hope this helps someone in the future.:(
26 Oct 2012 03:23 #2 by The Beard
Replied by The Beard on topic Re: ESC programming.
Wish it helped me now.
26 Oct 2012 05:48 #3 by a4kskyhawk
Replied by a4kskyhawk on topic Re: ESC programming.
here is a good tool to programme a esc, and most or all esc require you to have the trottle trim as low as it will go.
26 Oct 2012 13:40 #4 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Re: ESC programming.
It looks the same as the Hobbywing card, i tend to use the Hobbywing ESC's from GC and their cards i find them a very good ESC.
26 Oct 2012 13:55 #5 by The Beard
I have some of them,but you have to have the right card for the right ESC.
26 Oct 2012 14:22 - 26 Oct 2012 14:24 #6 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: ESC programming.
Thanks Sky, yes the right programming card does help. I've got an Emax one, but it won't talk to these ESCs! I wish I hadn't been so cheepskate and bought Turnigy, you only get what you pay for!
Last edit: 26 Oct 2012 14:24 by Klipkopwildlife.
26 Oct 2012 14:32 #7 by Garry Pollard
Replied by Garry Pollard on topic Re: ESC programming.
Unfortunatly, as is the case with most things, one manufacturers product will only operate THEIR units. Standardisation does not exist mores the pity
27 Oct 2012 07:01 #8 by The Beard
Most ESC are programmed already.You can programme them without a card by reading the instructions that come with them and listening to the bleeps emitted.Ive never been successful.I did programme some ones brake to stop the prop spinning on a glider,but it was pure luck that the card I happened to have matched his ESC.
27 Oct 2012 16:49 #9 by Quorneng
Replied by Quorneng on topic Re: ESC programming.
You can indeed programme an ESC using the Tx but then again every manufacturer assigns different methods, beeps and sequence to do it.
Fortunately with a modest power set up the default settings are usually fine with only the motor brake needing to be set for a folding prop and that is normally assigned to the first option.
The cheap 'no name' ones are worst because their programme seems to vary depending on whose 'chip' has been built in! :ohmy:
The worst so far I have found had no less than 20 options and with no instruction!
So with the throttle stick at full it beeped once then twice then three times.... all the way to 20, that's a total of 210 beeps, and then it started all over again. :pinch:
By trial and error I managed to find out what 3 of the options actually did but the rest seemed to do nothing until I came to one that stopped it working properly and I cant 'undo' it either! :angry:
Usually one of the options restores the factory default settings but if you don't know which one it is........ :S
27 Oct 2012 19:42 #10 by The Beard
Its the lack of instructions that's the thing or the translation is so bad you just get confused and give up
Time to create page: 0.209 seconds
