Futaba Failsafe
21 Apr 2016 12:01 #1
Futaba Failsafe was created by Klipkopwildlife
Since the difficulties that BB had with failsafe on his 14SG I have been meaning to do some checks. (The road to hell is paved with good intentions) Since all of my ESC are the type that shut down to 0rpm on no signal I assumed that this was the reason for no throttle failsafe. (Assumption is always the mother of fups)
Yesterday I had to modify the battery bay for my FunCub since it's battery had decided it was well past it's sell by date. While I was busy I decided to check failsafe using an old servo and a 5cell Rx battery. Guess what, nothing, no failsafe! Read this again, nothing, no failsafe!
Intrigued I then swapped Rx's, nothing! Finally I pulled out a Futaba RX (I don't use them because they're expensive and I would hate to lose one!) and hooked it up, bingo! Failsafe!
So there you have it, if you are using the El cheapo, Orange Rx's on Futaba you will have no failsafe! Question is, can you afford it?
21 Apr 2016 13:49 #2
by Garry Pollard
Replied by Garry Pollard on topic Futaba Failsafe
My answer to that would be a definite NO.
This does suprise me, as I use the Orange RX with Spekky and the failsafe is fine. Anyone who is using Futaba got any ideas ???
21 Apr 2016 14:41 #3
by The Beard
Replied by The Beard on topic Futaba Failsafe
yes i only use genuine
- Thank you received: 10722
21 Apr 2016 14:48 #4
Replied by THE BLACKBIRD on topic Futaba Failsafe
I HAVE FAILSAFE WITH A FUTABA 12 SG AND A ORANGE RX
- Si_B
- Thank you received: 680
21 Apr 2016 18:52 #5
by Si_B
Replied by Si_B on topic Futaba Failsafe
On the Frsky and Orange Rx's you actually get a better fail safe on the ones with less channels ( the 617 only gives you fail safe on throttle). You set the fail safe on the Rx not in the transmitter. Once everything is set up the way you want, you press the bind button and release. This stores you fail safe settings. You need to disable any failsafe in the Tx.
This is in the instructions for the receivers !!!
Simon
Simon
21 Apr 2016 19:04 - 21 Apr 2016 19:05 #6
Haaa you read the instructions Simon
Mine is set on the TX I think ???
Last edit: 21 Apr 2016 19:05 by THE BLACKBIRD.
21 Apr 2016 20:35 #7
Replied by Eric on topic Futaba Failsafe
With my 6EX and an Orange 6 channel receiver, I had a failsafe on signal loss, but not with the eight channel orange rx. Don't know why!
22 Apr 2016 18:32 #8
Replied by Klipkopwildlife on topic Futaba Failsafe
Duh, do you know how hard it is to wipe egg off your face! It's there on the RX instructions for all to see! And I'm the guy who says,'now it doesn't work, read the instructions!'
Thanks Si_B
Thanks Si_B
- Si_B
22 Apr 2016 20:12 #9
by Si_B
Don't have it set on the tx and the rx as it can cause glitching.
Simon
Simon
22 Apr 2016 20:40 #10
by one tenor
Replied by one tenor on topic Futaba Failsafe
Does anyone know if this works with the Microlite DSM2 6 Ch ?
Time to create page: 0.154 seconds
