Futaba 6EX PCM
  • Kenny850
  • New Member
  • New Member
  • Radio Idiot
06 Oct 2018 10:03 #1 by Kenny850
Futaba 6EX PCM was created by Kenny850
Please forgive my ignorance in these matters; I have recently acquired the above radio transmitter in unused condition with a couple of servos bu;t no receiver ; I would like to know what my options are particularly as the futaba receivers seem so expensive; regards Kenn
06 Oct 2018 11:43 #2 by Quorneng
Replied by Quorneng on topic Futaba 6EX PCM
Kenny850
I trust you are aware that the Futaba 6EX uses rather old technology.
I may be wrong but new 35 Mhz (In the UK it must be 35 for planes) receivers are getting a bit hard to come by although still easy enough if you don't mind second hand from ebay and the like.
Also be aware you will probably spend nearly as much on the crystals as for the receiver itself.
My advice is to always use matched pair transmitter and receiver crystals. Mixing brands may not work perfectly together even if they are the same frequency.
Although still quite usable (I still regularly use an even older Futaba 6A Skysport) it is a bit of a lottery buying second hand bits unless you know "what is what".
Thanks: Kenny850
06 Oct 2018 11:58 #3 by Eric
Replied by Eric on topic Futaba 6EX PCM
Also be aware that the style and size of servo plugs has changed over the years, from the five pin, to the three pin 'M' series, and now the much smaller crimped connection mini-plug (I don't know it's designation).
Thanks: Kenny850
06 Oct 2018 12:14 #4 by Klipkopwildlife
Replied by Klipkopwildlife on topic Futaba 6EX PCM
Corona used to do a 35mhz receiver that found the correct signal when told too. Cheap and reliable. If you feel capable you could upgrade your TX with this
I posted my conversion on this site. It's been super reliable, I tried to do a range check, I stopped at 2.1Km because I could no longer see the light I was using!
Thanks: Kenny850
  • Flytilbroke's Avatar
07 Oct 2018 10:04 #5 by Flytilbroke
Replied by Flytilbroke on topic Futaba 6EX PCM
As mentioned on reply to your introduction post. Check the regulations for what is allowed in France. Also if you are planning to use the old Radio tx you have, put a new battery pack in it. Quite a few folks still have some Futaba 35mHz rx's and Xtals pairs to match. When you know what you need just ask on the forum.
08 Oct 2018 04:15 #6 by one tenor
Replied by one tenor on topic Futaba 6EX PCM
Talking of which what is the best crimping tool for this?
08 Oct 2018 10:16 #7 by Klipkopwildlife
one tenor wrote: Talking of which what is the best crimping tool for this?
What John?
08 Oct 2018 12:27 #8 by Eric
I think he's responding to my post about three or four earlier, about servo plugs! :lol:
08 Oct 2018 14:20 #9 by Klipkopwildlife
I find a pair of old, blunt side cutters does the job, provided your careful. If you really want to be clever grind a small recess in each side with a Dremel.
Thanks: one tenor
11 Oct 2018 05:44 #10 by one tenor
I've two including the 50th Anniversary one. I'll use them when I'm fit enough.
19 Jan 2019 09:43 #11 by Klipkopwildlife
Bump to first page.
Time to create page: 0.486 seconds
