Problems with SD cards
I've updated my X9D+ to 2.2.4 from 2.1.1, but can I get it to write to the SD card? Can I heck!
Plan B is to put the card into one of those adapter thingies, and plug it directly into the pc.
Well, I found the appropriate thingy, and put the micro SD into it, and plugged it into the computer.
The computer decided it was drive N
so
I can read the contents
BUT the b$%^& thing is write protected! Tried to format it - same thing, write protected.
So how do I tell the card I want to write an updated programme to it?
Where's Mike Wood when he's needed?
I don't recommend using a Card reader, it tends to create multiple Logical drives and just confuses the issue. My favorite is this widget that plugs straight into the USB
I've not seen that direct usb plug before, I'll have to look for one for next time!
As these bits are off-topic to the Horus, feel free to remove them in a day or so, to tidy things up, when everyone has had a laugh on me!
Widget/gadget/thingy arrived today, tried it, SD card wiped and re-loaded with the new data.
Success.
Moved over from 'Using your Horus X12S'
- Hooligan Flyer
Took me a while before I found out what the problem was.
Micro SD's don't have a lock switch.
But still a very relevant comment.Eric wrote: You do realize you are replying to a 14 month old thread?
- Hooligan Flyer
As you stated above you tried using it in your PC with a SD card adapter and was locked which may have been your problem with it being write protected
If I recall, via the adaptor card, it would neither read nor write. The pc wasn't recognizing the gadget.
When I used the usb device, it worked both ways, straight away.
- Hooligan Flyer
