Flight Modes
16 Sep 2019 14:34 #1 by Klipkopwildlife
Flight Modes was created by Klipkopwildlife
Eric wrote,
Calibrate the modes. With modern computer radio, you can select an assortment of different flight modes, ie fixed wing power, f/w glider, v-tail, flying wing, helicopter, quad, etc etc.
So all the 'mixing' for driving the various control surfaces is done in the transmitter, not in the aircraft. This is much more flexible, in that you can mix anything to anything, and even which stick or switch controls it, and the transmitter remembers which settings to apply, depending on which model you have selected. You can also change the percentage of the mix at the field, without resorting to screwdrivers and wire-cutters!
Each time you switch on, though, you should still check that your flight controls move in the right directions!
16 Sep 2019 14:48 #2 by Klipkopwildlife
Replied by Klipkopwildlife on topic Flight Modes
Even from within the aircraft model memory you can assign switch or a rotary switch to change modes. Why would you want to do this? Suppose you have a Lancaster that has major pitch changes between U/C down and U/C up. Assign position 1 to take off with the correct trim and control movement to allow that mode without wetting yourself. Now you're ready to up U/C you need position 2 to retract with delay on one side while correcting with a bit of rudder and changing the trims in unison to give you proper flight control. Position 3 could be normal flight plus powering the turrets. Position 4 might be 2 engines out on one side with extended rudder sub trim and extra rudder. Position 5, landing, U/C down plus correct trims and possibly extra elevator for the flare.
These are just some of the possibilities, when you are flying your master piece you need all the help you can get, Flight modes can do this. Of course you also need sound to tell you what switch you've pressed, turned or flipped!
16 Sep 2019 15:12 #3 by Specialbuilder
Replied by Specialbuilder on topic Flight Modes
Hmm, well good luck with all that! I'm so pleased I don't do military. I may end up with a pooterised Tx., but since this "very old TX" has only been used 3 times now (due to a manufacturer's fault as much as my being busy) it'll have to be used as my modern, almost new one for a while yet. It's a Spektrum DX5e, btw. I bought it as a deal I could hardly refuse. I wish now I'd waited for the FrySky range, but they didn't exist then. Although I do have a FrSky 3 channel for my yacht.
I'm not sure I could be bothered with all that screen learning. OK, if a grand fell out of my back pocket and I rushed off and bought a Jeti Duplex, I might try learning, but otherwise, nah... I'll just learn to fly like a real one.
Martin
  • crash happy's Avatar
16 Sep 2019 16:13 #4 by crash happy
Replied by crash happy on topic Flight Modes
Martin wrote "I'm not sure I could be bothered with all that screen learning. OK, if a grand fell out of my back pocket and I rushed off and bought a Jeti Duplex, I might try learning, but otherwise, nah... I'll just learn to fly like a real one."
If I was starting again from scratch the first thing I would buy would be the best TX I could afford. Probably a minimum 8 channel & it certainly wouldn't cost a grand! :ohmy: The time taken learning to use a computerised TX has paid dividends ten times over.
As far as learning to fly like a real one, that is never going to happen due to one fundamental flaw, you ain't sitting in it !
Just saying. ;)
16 Sep 2019 18:49 #5 by Specialbuilder
Not a grand maybe, but about 5-600 for a second hand one. To me the most beautiful piece of hobby kit it's possible to buy. I would be happy to frame one and put it on the wall just to look at.
Funny how every body used to fly just like real ones before there were computers in their Txs! It must make complex aircraft easy, but I ain't a fan of complex. But getting the mixture of manual inputs just right is so satisfying.
Low, slow and smooth are my goals.
Martin
16 Sep 2019 20:17 #6 by paul d
Replied by paul d on topic Flight Modes
Sounds like you need to build a junior 60 Martin! I'm a bit of a vintage, traditional sort of chap, I do have a all singing computer radio but barely scratch the surface of its capability....
16 Sep 2019 20:53 #7 by crash happy
All comes down to "horses for courses" I guess. With my flying style I need all the help I can get ! :woohoo: [badass]
24 Sep 2019 11:33 #8 by Specialbuilder
OK, having had to re-bind for the umpteenth time to go from trainer (as yet unused) and Pietenpol (calm day, nice flight) I 've decided that if I'm to stay in this hobby, which it looks like I will, a pooterised Tx. wouldn't be a bad idea if only to save me the hassle of all that pluggery and beaping stuff, so I threw out a vague enquiry at the club about a good inexpensive buy and another member offered me his newly redundant DX7 for a steal of a price. So that will be my main Christmas present from my wife who never knows what to buy me (apart from Prog Rock CDs). I won't get it till Christmas, but got plenty to occupy me till then.
Of course, I won't have a clue how to "play screens", so may be asking awkward questions on here and elsewhere.
Martin
  • Flytilbroke's Avatar
02 Oct 2019 09:45 #9 by Flytilbroke
Replied by Flytilbroke on topic Flight Modes
You are in for a treat with the DX7,,,,, not.
I have had one since they came out and loved it. But.... it is quirky to program for more than the basic functions. Which at the moment will suit you I think.
06 Oct 2019 10:55 #10 by Specialbuilder
Not sure I even know what the basic functions are! Rates and a bit of expo will be about my limit. Elevon mixing for a delta or a wing. That's all I plan on getting involved with. And there are several flyers in the club who use them and would help me through the process. I then have all I need to decide if this is the hobby for me. Weather is a constant consideration. Is the insurance scam and club fees worth the limited amount of flying time available? Do I get a big enough kick out of it? Those sort of things. I'm far more a builder than a flyer really. We shall see. But if I build and get someone else to fly 'em, would that be enough?
Gummint interference could be the killer.
Martin
06 Oct 2019 13:14 #11 by Quorneng
Replied by Quorneng on topic Flight Modes
Martin
It is not uncommon for modellers to spend more time building than flying.
My building to flying ratio is probably in the order of several hundred to one!
I do however get considerable satisfaction from finding out if a self design and build actually performs as I intended even though it may not be flown that much thereafter.
I do have insurance but have the advantage of being to be able to use a local field for free so my limited flying hours has no direct financial penalty.
Just saying!
06 Oct 2019 13:47 #12 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Flight Modes
I enjoy the building more than the flying
Having said that i have not flown since christmas day last year that i can remember
So should i join a club here, to be honest i may not
Costs of club fees, insurance, the bloody A test, the noise issues
Club rules ect ect
06 Oct 2019 14:05 #13 by crash happy
If you ever find yourself out this way you are welcome to fly at our club anytime ! Apart from insurance we don't have any of that, oh yes there are a couple of rules; Shut the clubhouse door on the way out & try not to crash into my car ! :whistle: :)
PS. That's an open invitation.
06 Oct 2019 14:18 #14 by Klipkopwildlife
Special builder wrote "Weather is a constant consideration. Is the insurance scam and club fees worth the limited amount of flying time available?"
Living on an overcrowded island as most of you do I think insurance is a must, and try getting it anywhere else other than though the BFMA. I certainly would not dream of flying without it. As for flying time, yes certain parts of the UK can seem very wet at times, as for wind stopping play, once you're able to fly unsupervised you'll get much more flying in. Eric seems to get plenty. Remember that Vintage models are not well suited to windy conditions, the same goes (but not quite so much) for 3 channel models. You eventually settle on a hack that can be flown just about any time and a number of other planes that require the selection of the right conditions.
06 Oct 2019 16:26 #15 by Eric
Replied by Eric on topic Flight Modes
Eric seems to get plenty. - I hope you meant flying, Tony! (see been flying, today!)
Time to create page: 0.316 seconds
