LM555 timer
25 Aug 2020 18:58 #1 by Klipkopwildlife
LM555 timer was created by Klipkopwildlife
Our servos get their position from the width of a pulse that's repeated 50 times per second. The pulse measures 1.1mS at one end of the travel, 1.5mS to centre and 1.9mS to go the other end, these are industry standards. It's a simple matter to make a circuit that will drive the servo to a point using a LM555 integrated circuit.
This is the circuit and you can change resistances according to this chart and formula.
Add a small relay and you can easily make your servo go to 2 different positions for operating points on a railroad for example.
The IC can take any voltage up to about 30 and can easily source enough current to drive a servo.
25 Aug 2020 19:55 #2 by paul d
Replied by paul d on topic LM555 timer
That takes me back Klippy! about a million years ago before I did my engineering apprenticeship I done a year at college doing electronic servicing, we used to use 555 timers to make simple circuits.
26 Aug 2020 08:15 #3 by Eric
Replied by Eric on topic LM555 timer
The 555 varies in price from around 30 to 50 pence each, (plus p+p) then you need the external components and a circuit board, although you could use Veroboard, if you can find any!
Time to create page: 0.145 seconds
