strange one
06 Jan 2021 09:01 #1
by paul d
strange one was created by paul d
Amongst the pile of repairs I've got is a speed boat, guy crashed it and partially sunk it. I've changed the smashed prop and 're attached the shaft to the motor and replaced the water logged rx but when I plug in the battery the motor bursts into life! it's a water cooled and sealed esc. can these things fail "on"?
- Thank you received: 14305
06 Jan 2021 12:22 #2
Replied by Eric on topic strange one
The speed controller could be reversed. Open the tx throttle fully, then plug in the rx battery, and see what happens!
If the speedo then follows the stick 'backwards', you know what the solution is!
06 Jan 2021 12:34 #3
Replied by Quorneng on topic strange one
Was his or your Tx different and was one a Futaba?
Their throttles work in opposition to everyone else.
06 Jan 2021 15:49 #4
by paul d
Replied by paul d on topic strange one
All sorted chaps, the Speedo had failed "on" probably due to the whack the prop shaft and motor had, always assumed they failed safe?
Simon, I didn't just fit a new rx, it was a obscure make so it's had a new one with matching tx.
Time to create page: 0.147 seconds
