- Thank you received: 344
- Forum
- Forum Categories
- Technical Stuff, Radio Gear, Electronics.
- Futaba t4vf skysport4 tx / fp-r115f rx
- Rich griff
01 Jul 2021 09:52 #1
by Rich griff
Futaba t4vf skysport4 tx / fp-r115f rx was created by Rich griff
Might anyone on here has a service manual/test procedure/test info on this combo please ?
My friend mo said it did work as he was using it on an rc car, naughty boy!
Crystals same, 66. Marked tx and Rx.
Tx signal spot on as seen on scope, but when sticks twiddled I cannot see any "movement" or change.
I would have thought that something would be seen.
The Rx aerial wire seems ok, continuity from end to circuit board.
Tx on, tx output gauge shows 100percent, Rx powered up ( servo movement on power up ) but no servo response when sticks twiddled.
Anyone have a test procedure/expected results/scope traces/schematics for this combo please.
I know of manualslib but not fully investigated there yet.
May enquire with ripmax but they were hopeless with last enquiry.
Is it tx problem or Rx problem...
Any/all help greatly appreciated.
rich
rich
01 Jul 2021 10:23 - 01 Jul 2021 10:33 #2
Replied by Eric on topic Futaba t4vf skysport4 tx / fp-r115f rx
27 or 35 Megs?
I've a Skysport 6 (T6YG) on 35, and I'll try to find the manual - haven't seen it for ages!
edit
If the rx crystal has been dropped or violently shaken, it can go 'off' and fail to work - they're surprisingly fragile!
You say it was in a car, so at a best guess, I'd say the rx was off tune.
If you have a scanner or other radio that can tune to somewhere near - hold it close, and listen for a burring noise that changes pitch when you move the tx sticks.
Is the meter on the tx marked output or batt? Mine shows output.
Are BOTH crystals Futaba, or someone else's? Different manufacturers use different resonances, so your tx can be way off - with 'foreign' crystals.
There's no 'bind' option with crystal sets - they either work or they don't!
edit
Last edit: 01 Jul 2021 10:33 by Eric. Reason: added a comment
- Rich griff
01 Jul 2021 10:47 #3
by Rich griff
Replied by Rich griff on topic Futaba t4vf skysport4 tx / fp-r115f rx
Hi Eric, it's a 35 meg set and both crystal 66 marked tx and Rx appear to be Futaba.
The tx meter is marked "output"...
Will have a go at the "listening" test technique...
Would be good to get this set working, I have no similar set for substitution test.
The challenger has a dual conversion Rx...
I would have thought that something would be seen to change on the scope when the tx sticks are twiddled, nothing was seen, just a rock solid and spot on carrier wave...
01 Jul 2021 12:29 #4
I suspect you were measuring the rf out, not the data train IN the rf!
You should see four sequential square waves of around 1.5 milliseconds, one for each channel - the length of which varies as you move a stick - and a longer 'start' marker - which synchronises the rx with the tx.
- Rich griff
01 Jul 2021 13:25 #5
by Rich griff
Yes, looking at RF out, but would not the "message" be mixed, superimposed with the carrier wave, and seen ?
Will have an other go later...
01 Jul 2021 18:24 - 01 Jul 2021 18:24 #6
Replied by Quorneng on topic Futaba t4vf skysport4 tx / fp-r115f rx
Rich
You mentioned dual conversion. If the rx is dual conversion the crystals have to be dual conversion and a matched pair. Dual conversion use a second frequency that is selected by the manufacturer. A single conversion crystal will not work with a dual rx.
Single conversion crystals can be 'mixed & matched' between manufacturers. I do on my 35 meg Skysport.
Last edit: 01 Jul 2021 18:24 by Quorneng.
- Rich griff
01 Jul 2021 19:09 - 01 Jul 2021 19:12 #7
by Rich griff
Thanks for that, I didn't really want to put the challenger crystals into the skysport4 just in case it buggered them.
Would you have any tech info on the skysport4 ?
What kneck of the woods do you live in ?
I need to establish if the Rx works, how would you feel about...if I sent the Rx to you with a prepaid padded envelope for its return, if you could put your Rx crystal in it and see if your tx will work it ?
This would establish if the Rx works...
Without a test procedure I am in the dark...
There is no rush on this...
I have contacted ripmax Futaba for help/info but i am not holding my breath...
I have found an other possible source of info for Futaba but they are a USA based web address...
Last edit: 01 Jul 2021 19:12 by Rich griff.
01 Jul 2021 19:34 #8
Rich
You can download a Skysport 4 user manual here for free. It is all pretty basic.
Not quite sure about fp-r115f as these are the numbers for a 5 ch Futaba transmitter.
You can certainly send me your rx and I will test it. I will pm you my address.
I note there is a Futaba SKYSPORT T4VF for sale on Ebay £12.99 + £4.50 postage. It might be easier to use that than to fix a fault.
01 Jul 2021 20:08 #9
I may be incorrect, but a five channel rx will not follow a four channel tx, the data pulse timing will be wrong, so it may treat the incoming signal as noise, and ignore it!
The other way around would work, as the surplus channels would be ignored - the synchronising 'start' pulse is the important one.
02 Jul 2021 08:22 #10
Replied by Klipkopwildlife on topic Futaba t4vf skysport4 tx / fp-r115f rx
I might have to disagree Eric. The repeat frequency is usually 50hertz, that is 1000/50 = 20milliseconds for each complete set of channels, the channel information is standard for all servos at about 0.5mS to 1.9mS from full in one direction to full in the other, about every 2.5mS. Once the TX has sent all the available channels it waits until the end of the 20mS and then repeats itself. The receiver listens for the sequence, if it's a 5 channel RX but it only gets 4 sets of information it will recognise the wait period and be ready for the next set of 4.
My thoughts on the matter, I could be wrong.
Rich, when checking the RF are you using a diode and a resistor in series to the antenna? This may make a difference to the trace that you see.
- Rich griff
02 Jul 2021 10:40 #11
by Rich griff
I must make notes where is see)read stuff, print outs would be good, saves those oh so common ( for me ) moments of " wtf did I see that on the dam nternet !".
I have seen a Futaba instruction sheet somewhere that lists comparable Futaba RX's, the r115f being one of them.
Now your getting technical, resister and diode, to drop output and demodulate ?
Will be checking challenger output to see for any changes, if changes seen when twiddling the sticks and that set works ( no t tested yet, roof repair before it rains again ) will try the skysport4 again.
Yet to do "listening" test with radio...
This set is a bit redundant as it don't work ( yet ) so is on the back burner...
But thanks for your help and input, much appreciated.
It's Moe's set, left to him with lots of other stuff by his late uncle. His family had a trajic years last year, lost three family members, not to covid...
- Rich griff
02 Jul 2021 10:46 #12
by Rich griff
Thanks quorneng, that's the one...
Must get roof done before w before it rains...
- Forum
- Forum Categories
Time to create page: 0.479 seconds
