Engine not getting fuel
  • squareflux
29 Nov 2021 21:30 #1 by squareflux
Engine not getting fuel was created by squareflux
Hi. I’m running an engine on my test stand, but it’s got a problem with not getting fuel.
When I try to prime it by covering the venturi, I see fuel coming up the line to the inlet at the carb on the compression stroke, then it goes back down the line after compression.
So it takes more turns to prime it. The engine will then start and run, but only till the fuel in it is burned, then it dies.
I’m using a starter motor to start it.
What could be causing this?
It’s a Super Tigre G75, that’s had new bearings and a new piston ring.
Could the carb be needing cleaned, or something else?
29 Nov 2021 22:29 #2 by Quorneng
Replied by Quorneng on topic Engine not getting fuel
I will put in my two pennyworth
In a normal set up there is nothing physically stopping the fuel flowing back from the carb so it will tend to flow back.
As the engine won't keep the fuel flowing my first guess is an air leak where the fuel tube joins the carb.
My second guess, and less likely, is the tank fuel level is so low such that the carb vacuum from the venturi is not strong enough to keep the fuel flowing.
29 Nov 2021 22:53 #3 by Eric
Replied by Eric on topic Engine not getting fuel
If you can't raise the tank, try an exhaust pressure feed.
30 Nov 2021 07:21 #4 by paul d
Replied by paul d on topic Engine not getting fuel
Sounds like a air leak or a blockage, any bubbles in the fuel line?
Try taking the needle out and blowing through the spray bar.
30 Nov 2021 07:25 - 30 Nov 2021 07:26 #5 by Klipkopwildlife
Replied by Klipkopwildlife on topic Engine not getting fuel
Is the spray bar correctly fitted? Try raising the clunk above the carburettor, then try again.
Last edit: 30 Nov 2021 07:26 by Klipkopwildlife.
  • squareflux
30 Nov 2021 19:51 #6 by squareflux
Replied by squareflux on topic Engine not getting fuel
Thanks for the suggestions. I’ll try some of those and see how it goes.
Time to create page: 0.237 seconds
