Well that's me grounded
27 Sep 2011 20:51 #31
by Garry Pollard
Replied by Garry Pollard on topic Re: Well that's me grounded
Andy,
Any chance of talking bloop through this one mate. Better maybe to do it by PM, although it might make interesting reading.
27 Sep 2011 22:37 - 27 Sep 2011 22:37 #32
Replied by Eric on topic Re: Well that's me grounded
On my futaba tx's - the screws holding the sticks in are on the front of the case, four to each. The circuit board on the back of the stick doesn't need to be touched.
The snag is - the sticks have to be rotated 90 degrees for the trimmers to line up with the holes in the case, so you end up with the throttle working left/right. the rudder working up/down, etc!
All that needs to be done, really, is to take the little flat ratchet spring off the throttle stick, and the coil spring off the ele stick, put the ratchet spring on the (old) ele stick, and the coil spring on the (old) throttle stick. job done! (Then remember the sockets on the rx are marked wrong!)
Getting the little coil spring onto the plastic hooky things that centre the stick is a right pain, though! Tie a length of cotton to the spring BEFORE you touch it, or you will spend a month looking for it when it flirts off!
This works on a simple tx, but if you are computerised, with about thirty different mixer options, then the fun starts!
Last edit: 27 Sep 2011 22:37 by Eric. Reason: added a few words to clarify something
27 Sep 2011 22:47 #33
Replied by Klipkopwildlife on topic Re: Well that's me grounded
Nail on head as usual Eric.
- blooper
27 Sep 2011 23:23 #34
by blooper
Replied by blooper on topic Re: Well that's me grounded
hmmm sticks working the wrong way.
i think i best leave it alone and learn to fly mode 1.
- andy_mann
28 Sep 2011 00:44 - 28 Sep 2011 00:44 #35
by andy_mann
Replied by andy_mann on topic Re: Well that's me grounded
bloop you only have to move the ratchet over then change it on tx all the sticks then work as per mode 2
its unscrew lift spring and move over to other side if you have probs I will down the info and try to sort out never thought about before other wise would have done it for you
Last edit: 28 Sep 2011 00:44 by andy_mann.
- blooper
28 Sep 2011 01:40 #36
by blooper
sorted.
thanks andy.
the fittings from one side go upside down on the other, only took 10 mins in the end.
all sorted now and the plane is set up ready to go.
thanks andy.
28 Sep 2011 01:48 #37
by Garry Pollard
Dont forget to range check it before flying Bloop
28 Sep 2011 02:52 #38
Dead easy once you pluck up the courage, wasn't it?
- blooper
29 Sep 2011 03:09 #39
by blooper
tx worked fine tonight.
i am flying again.
well i was until the prop fell off mid flight.
i am flying again.
Time to create page: 0.889 seconds
