4 motor wiring
  • blooper
29 Sep 2011 03:17 #1 by blooper
4 motor wiring was created by blooper
hello folks and garry.
i will be needing advice on the best way to wire up 4 motors, esc's and bec for my vickers build very shortly.
i have 2 engines in each pod, 1 tractor and 1 pusher.
i will fit the esc's in the pods and have the batteries in the fuselage.
tractors will run off of 1 battery and pushers the other.
then a separate battery for the rec and servo's.
hints and tips required.
thank you in advance.
tony. (blooper)
29 Sep 2011 11:24 #2 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: 4 motor wiring
You'll have to remove (fold back) the red wires from each Esc, and you'll need three 'Y' leads, one for the pushers and one for the pullers and one to go to the receiver. It might be easier to make up a loom.
I'll post a schematic if you need one bloop.
  • blooper
29 Sep 2011 13:43 #3 by blooper
Replied by blooper on topic Re: 4 motor wiring
if you could sir it will be a great help.
i have to feed all the wires down the supports and into the wing as well. (should be fun)
tony.
30 Sep 2011 03:16 #4 by Eric
Replied by Eric on topic Re: 4 motor wiring
Plug your receiver battery in to the receiver, as normal.
Take the first Y lead, and disconnect the red lead from the rx plug. Plug this into the throttle socket on the rx.
Take another two Y leads, plug them into the two ends you already have, so you now have four sockets.
Plug a speedo into each one.
Plug each speedo into a motor and a lipo as normal.
By disconnecting the red wire in the first Y lead, you have stopped the speedos from feeding the rx with volts, and fighting each other!
Normally you do not need to separate all the red leads, because it is just the same as having four batteries side by side, they won't fight each other.
  • andy_mann
30 Sep 2011 14:01 #5 by andy_mann
Replied by andy_mann on topic Re: 4 motor wiring
thats good info thanks
02 Sep 2012 00:00 #6 by The Beard
Replied by The Beard on topic Re: 4 motor wiring
Youll be needing this one now Tony
02 Sep 2012 04:01 #7 by Quorneng
Replied by Quorneng on topic Re: 4 motor wiring
Just one point.
With the ESCs in the pods they will be close to their motors but how long will the battery wires be?
There is no practical limit on the length of the ESC to motor wires but there is on the battery to ESC. The smoothing capacitors on the input side of the ESC can be damaged by stray induced voltages and the longer the battery wires the more likely is it to happen.
Time to create page: 0.169 seconds
