Durafly Supermarine Spitfire Mk5b
  • DominicM
  • DominicM's Avatar Topic Author
  • Vlogger for 'Essential RC'
03 Jun 2016 08:06 - 21 Jul 2016 21:22 #1 by DominicM
Durafly Supermarine Spitfire Mk5b was created by DominicM
The newest version of the Spitfire from Durafly. This version with much improved scale detailing. It can certainly handle the wind. Can't wait to fly it on a calm sunny day.
www.youtube.com/c/essentialRC
Last edit: 21 Jul 2016 21:22 by .
03 Jun 2016 09:42 - 03 Jun 2016 09:45 #2 by Eric
Replied by Eric on topic Durafly Supemarine Spitfire Mk5b
The Spit looks right in the air, albeit a bit light, typically foamy. I understand the retracts are ali and nylon, not the usual brittle plastic, is that correct?
I have been contemplating getting one, until Parcelforce lost my previous Hobbyking parcel, (separate thread!) so until that is resolved, I'm not ordering anything from them.
I' pleased that you mentioned the ball links instead of clevises. I'd have to send for some suitable pliers as well!
Last edit: 03 Jun 2016 09:45 by Eric. Reason: changed wording
  • DominicM
03 Jun 2016 12:11 #3 by DominicM
Replied by DominicM on topic Durafly Supemarine Spitfire Mk5b
It was the worst day for flying really Eric. I wouldn't go by that. Hoping to get SOME sun in the near future so I can so nice low aeros with it. You will have noticed I hadn't taken the front protective film off the decals either. Very embarrasing. Have done that now and it looks superb.
03 Jun 2016 20:52 #4 by Quorneng
Replied by Quorneng on topic Durafly Supemarine Spitfire Mk5b
In the video you said the flaps descented quite a bit - looks about 30 degrees - but of course on all Spitfires (except the Mk47) the flaps only had two positions 0 and 60 degrees - unless the "for take off only" wooden wedge trick was used! ;)
04 Jun 2016 07:52 #5 by Eric
As Q put, they were air-brakes, not flaps, to slow the slippery beast down!
04 Jun 2016 13:19 #6 by The Beard
Replied by The Beard on topic Durafly Supemarine Spitfire Mk5b
interesting is this model only available through hobby king how much please
04 Jun 2016 13:47 #7 by Klipkopwildlife
Replied by Klipkopwildlife on topic Durafly Supemarine Spitfire Mk5b
It's 136.64 Gbp from the EU warehouse Stephen, looks like Durafly make bespoke units for HobbyKing.
04 Jun 2016 13:53 #8 by Klipkopwildlife
I don't have sound, did you fly it on 3S or 4S Dominic?
04 Jun 2016 21:32 #9 by Eric
Dom said he flew it on 4S, Klippy, but it will fly on a 3.
04 Jun 2016 22:24 #10 by one tenor
Replied by one tenor on topic Durafly Supemarine Spitfire Mk5b
Not heard of the wedge dodge .What is it >
04 Jun 2016 23:30 - 04 Jun 2016 23:32 #11 by Quorneng
In May 1942 the USS Wasp and HMS Eagle carriers went into the Med to deliver 64 ordinary land based Spitfires to Malta.
The Spits had to have over load tanks to give them the required range.
To help get them off the deck they needed 15 degrees of flap but the pneumatically operated flaps only had two position 0 & 60 degrees.
The pneumatics cylinders only worked one way so the flaps had a spring return.
Just before take off the flaps were dropped and wooden wedges held in place so when retracted they were held at 15 degrees.
After take off the flaps were fully deployed, the wedges would fall out and the flaps could then be fully retracted.
Last edit: 04 Jun 2016 23:32 by Quorneng.
Thanks: one tenor
05 Jun 2016 07:54 - 05 Jun 2016 08:11 #12 by Ex-Member
Replied by Ex-Member on topic Durafly Supemarine Spitfire Mk5b
Flap travel of all the Spitfires I've flown was closer to 90 degrees, not 60 degrees, Q. I seem to remember that 85 degrees was the figure, but I'll check*. You're right about the use of the wedges, though.
With such a large flap deflection, they cover the outlet of the radiators and on the early marks, the oil cooler, which makes it a major problem if the flaps don't retract. One of the good design points, though, was the trim. The aircraft pitches down significantly as the flaps are deployed but the pitch trim remains about the same, indicating that Mitchell got it right!
*Addendum - the Spitfire Mk V manual gives the down position as 85 degrees.
Last edit: 05 Jun 2016 08:11 by Ex-Member.
05 Jun 2016 13:39 #13 by Quorneng
My mistake.
I was relying on memory - should have checked! ;)
07 Jun 2016 11:52 #14 by one tenor
Mitchel was ahead of his time . a genius in my :opinion :woohoo: [badass]
07 Jun 2016 12:06 #15 by Klipkopwildlife
I second that, we don't speak German largely because of him! I still get goose bumps whenever I watch the movie of his life!
Time to create page: 0.239 seconds
