Blackhorse P40 Tomahawk
  • The Beard
02 Dec 2011 01:54 #1 by The Beard
Blackhorse P40 Tomahawk was created by The Beard
I bought this model about 18 months ago and started putting it together.Fitted a new SC91 4 str and all was going well.Then I started reading reports that the twist and turn under carriage was so bad that it was falling to pieces on maiden take off or on its first landing.The fault appeared to be just not enough thread holding it together so it was pulling apart.Some people tried to modify it without success and others just gave up.I was worried because you can see the servo for the retracts is in the middle of the fuselage so unless you transported it fully built you would have to set the under carriage up every time.I decided to wait until Electric twist and turn Retracts were available in 91 size,but so far no luck
  • The Beard
04 Dec 2011 16:36 #2 by The Beard
Replied by The Beard on topic Re: Blackhorse P40 Tomahawk
You can see the servo in the middle of the fuselage
04 Dec 2011 19:20 #3 by Phil Wood
Replied by Phil Wood on topic Re: Blackhorse P40 Tomahawk
That does look a silly design... even if you fitted snap on ball links to the arms, you'd still need to be a gynecologist to to get your hands in to fit them whilst fitting the wing.
Do what Tony suggests ... rip that servo out & fit it in the wing. ;)
05 Dec 2011 20:29 #4 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: Blackhorse P40 Tomahawk
They say these are for 60 - 120 Stephen, stevewebb.co.uk/index.php?pid=EFLG400&area=RET
Might be worth a look, can't afford them myself!
Time to create page: 0.191 seconds
