top flite sea fury
- Phil Wood
- Inactivated User
It does look like it's going to be very tail heavy & you may want to drill some lightening holes in the tail & film or tissue it.
- Dean M
- Thank you received: 326
will this be an electric conversion?
I nearly choked on my latte.
www.fleetairarmarchive.net/aircraft/seafury.html
will be making my own cowl out of wood and ali sheet, to be able to fit battery trays in there.
the canopy is about the same shape and size as a mustang one, so i will be making one of them as well.
debating covering it first with light weight tissue and 2 coats of poly c, then cutting each individual panel from heavy weight tissue and sticking them on to make the panel lines spot on.
the mark up the rivets and paint, final sealer coats and jobs done.
