Yet another Super Cub - but a bit different.
Really!
This I have got to find out for myself so I aim to build a true scale 40" Super Cub using this 3 view but its rudder will be fixed!
Can't wait to see how it turns.
- Inactivated User
- Inactivated User
and cubs should be kept away from learners, everyone thinks cubs are nice, easy fly pretty things, they bite, and bite hard, if not used properly, or set up properly
We shall see.
- barry
The old carl goldberg cub (greatplanes now) was a great trainer with a full wing and with clipped wings extremely aerobatic..
Ive own a number of cubs in various sizes , the worst one was an arf from china .. it did do exactly what alan cantwell describes . dropping its tail making it almost unflyable by anyone who couldnt fly a turn with alieron and rudder . . It had no dihedral and clipped wings .. was over powered and required alot of incidence changing of the wing and thrust angle on the motor to tame it .. generally it was horrible ..
All my other cubs fly sweet . the clipped wing models do require rudder input on the turn
I see two common problems from guys with cubs , over powering and flying too fast ..
Alot of cheaper cubs seem to use not much more than a clark y or flat bottom wing that lifts greatly when over powered . This lifting effect in a alieron turn gives the tail drop talked of ..
Eric reported a flick roll of his decathalon when given full rudder .. could this be a slightly tail heavy plane .. do you have it balance for aerobatics or regular flying eric.. once again speed can do this too if tail heavy..
Open to you thoughts and suggestions .
Thankyou.
- CeeJayP
- Hi Peeps
- Thank you received: 833
Al surely you dont need opposite rudder in a turn this will just shove the tail down the wrong way, the rudder keeps the tail up in a turn,and i agree differential on ailerons as the down going one can give a lot of drag (think flaps) and can cause adverse tourque and it will try to turn towards the drag, i can give you the sequence for a turn on a WW1 er (DH2 aileron differential is probably 80% 20% on this, my Morane type N a few years ago was 95% 5%) the turn is predominantly rudder but wings banked slightly with ailerons then rudder fed in to get correct turn radii and to keep tail up and to stop it tucking into the turn, which it loves to do, no fuselage remember, then opposite aileron to keep the wings at a good angle but the turn is rudder, ailerons are the ballance, so a tight left turn say will be lots of rudder with almost full right aileron and the amount of aileron depends on which way i am turning with the drive being in the middle pushing it does strange things, now my 1/3 tripacer similar layout to a cub makes nice long flat turns with a touch of rudder (its huge) and a nice bit of opposite aileron, it will do the bank and yank type turns, aileron and elevator, but looks wrong and is hard work when towing, flat turns make a nicer tow!!
chris
- Inactivated User
and i did not say they fly bad, i said they ned setting up, that long wing needs help, and that help comes from the waggly thing at the back, that, and copiuos amounts of differential,
another thing about the trainer thing, no model that has all the strength taken out, and replaced with glass, wil survive the tyro flyers learning, first time it goes tits up, it will be broken around the cabin area, this is anything with glass, and not wood, not just the cub
- CeeJayP
- Hi Peeps
cjp
Admittedly it is over-powered, but once off the ground I use that clicky lever on the transmitter, that slows things down!
The main reason for the flicking is I've got a bit too much control movement. Fly it gently, and it's a pussy-cat, but pussy-cats can claw and bite!
I like it like that, because it keeps my reflexes awake, never knowing which way it is going to 'depart' if I get too enthusiastic on the sticks!
- Inactivated User
- CeeJayP
- Hi Peeps
alan cantwell wrote: ive turned Daves 1/4 scale cub, intiitated the turn with CAR, and had to shove opposite in to tidy it up
i only commented on supplied information
cjp
