turman models bf 109 by roy scott. restoration.
26 Oct 2013 09:49 - 26 Oct 2013 09:57 #1 by Ex-Member
Going to start a new thread for this, to enable me to collect info in one place ready for the restoration of this bird.
alan cantwell wrote:
Tony B wrote: i think it is an early yt bf109.
the fiberglass fuselage has been snapped in half, not sure if it is repairable.
we did this owd bird at length in chat last night, its not a YT bird,(me thinks i should know :) ) but it IS a rarer beast, its a Turman models ME109, early kit designed by Roy Scott, great flyer, and the first super scale kit offered to the public, in its day, it was a BIGGUN, being 72inch, i think its well worth restoration, BUT, it has to be kept light, we discussed the way forward last night, the fuzz is polyester, i cannot remember if it is woven, or chopped mat, any input would be good, as said, the damage is around the CG, if there is enough mating parts there, then restoration is doable, the YT canopy will fit, the cowls there, the retracts are there, the wing is in one piece, What do you reckon? should Tony go for it? i have sent Tony a piccy of a flying one, something to salivate over, :) one thing, super glue will not work, but epoxy will,
Last edit: 26 Oct 2013 09:57 by Ex-Member.
26 Oct 2013 09:55 - 26 Oct 2013 09:55 #2 by Ex-Member
Replied by Ex-Member on topic turman models bf 109 by roy scott.
Here are the pics as it stands.
air retracts.
flaps and ailerons work via bellcranks and single servo's in the wing center.
the wing looks to be built up and skinned with fiberglass sheet, lots of detail.
Hollow glass fuselage, tailplane and fin are also fiberglass (i think)
the break is clean with no bits missing.
no wooden formers left in the center of the fuse and the steerable tail wheel former has come unglued.
pull pull wires on the rudder and elevator are broken.
more info needed please.
tony.
Last edit: 26 Oct 2013 09:55 by Ex-Member.
26 Oct 2013 09:56 #3 by Ex-Member
picture Alan posted earlier. (thanks Alan)
26 Oct 2013 11:40 #4 by The Beard
Replied by The Beard on topic turman models bf 109 by roy scott. restoration.
Cracking looking model but probably a challenge to fly
26 Oct 2013 12:39 #5 by Eric
It looks as though the previous owner found that out! :evil: That tapered wing would snap-roll if it was stalled. (The real one did - hence the auto-slats!)
Thanks: The Beard
  • alan cantwell
  • alan cantwell's Avatar
  • Inactivated User
  • Inactivated User
26 Oct 2013 13:52 #6 by alan cantwell
Replied by alan cantwell on topic turman models bf 109 by roy scott. restoration.
due to the varying wing sections, the stall was benign, Roy knew what he was about, its most important that the lateral balance of the model,once completed, is correct, its most difficult trait is keeping it straight on take off, the undercart is further apart from scale, but still care is needed with the take off roll, once up, she is a pussycat, how do i know? i flew one for a while, until offered silly money for it, before this, Ian Redshaw made one that gained silver at the model engineer contest, stitch it together Tony, but watch the weight as for the detail, you wont save it, apart from the fuz, the wing needs flatting, remove all rads, bumps and blisters, and treat it as a new build, if the wing is glassed, then it will flat back with wet& dry very nicely, go for it Tony, bit of history there
28 Oct 2013 11:18 #7 by Klipkopwildlife
Replied by Klipkopwildlife on topic turman models bf 109 by roy scott. restoration.
If I can make a suggestion, if you do repair this model fuselage, use only 24hr Araldite, it's the only stuff that I've found to be reliable at all temperatures and humidities.
  • alan cantwell
  • Inactivated User
  • Inactivated User
28 Oct 2013 18:03 - 30 Oct 2013 20:50 #8 by alan cantwell
Thats e-poxy suggestion, :silly: as long as you can get it thin enough to penetrate the fibres, cant see a problem, for me, it would be wing skinning epoxy, with thin cloth, i also have another ingredient, carbon fibre dust, its the produce of turning carbon fibre, put it into wing skinning epoxy, and the strength is incredible, i will send Tony some, if he is good,
Last edit: 30 Oct 2013 20:50 by .
28 Oct 2013 18:11 - 28 Oct 2013 18:12 #9 by Ex-Member
Replied by Ex-Member on topic turman models bf 109 by roy scott. restoration.
how about using a wing bandage with the thin epoxy they supply.
i am never good. :woohoo:
Last edit: 28 Oct 2013 18:12 by Ex-Member.
  • alan cantwell
  • Inactivated User
  • Inactivated User
28 Oct 2013 18:29 #10 by alan cantwell
Wing bandage is tooooooo thick, soak up too much epoxy, if the fuz is chopped matt, then use chopped mat, if its woven cloth, then use that, but it must be thin, multiple layers are ok, small enough to cover the repair, then bigger, then bigger again, this reinforces the join, and spreads the load down the layers, use a single layer of thick stuff, or several same size of thin stuff, and you create a shear point,
and i know you are not good, so, go stand in the corner for the rest of the night
29 Oct 2013 07:11 #11 by Klipkopwildlife
Must be the crap 'poxy' we get here, and, sadly Araldite is no longer available. :(
29 Oct 2013 21:42 #12 by Ex-Member
but would the wing bandage epoxy be ok to use.
i can get that and thin mat from rc world.
  • alan cantwell
  • Inactivated User
  • Inactivated User
30 Oct 2013 18:19 #13 by alan cantwell
Dont think so, its a tad thick,
30 Jan 2014 13:01 #14 by Ex-Member
i have been informed that is is an "emile" flown by Franz Von Werra. ( the one that got away)
shot down in 1940 over kent.
i must get round to looking at the fuselage soon.
  • alan cantwell
  • Inactivated User
  • Inactivated User
30 Jan 2014 18:47 #15 by alan cantwell
Looking at a fuselage would be great, NOT THE 2 HALVES, gerrit done, :evil:
Time to create page: 0.216 seconds
