avro shackleton mk111
03 Feb 2014 23:36 #1 by Ex-Member
avro shackleton mk111 was created by Ex-Member
Hello gents and ladies, let us start again.
My new project for 2014 is going to be a 10' wingspan avro shackleton mkIII.
In conjunction with Laser craft services , who are drawing up the initial plans.
The plan is to build the fuselage first, modifying the initial plans as we go along with the aim of being able to offer a plan set for retail sale at a later date.
There might also be a set of laser cut ribs and formers available as well in time.
here are a few of the initial cad designs to whet your appetite.
the original nose i constructed from my hand drawn sketch, will be finished as Alan suggested a display model for wall hanging.
keep watching folks, this could get interesting.
tony,
04 Feb 2014 08:52 #2 by Garry Pollard
Replied by Garry Pollard on topic avro shackleton mk111
Good luck with this venture Tony. It looks very interesting
04 Feb 2014 09:14 #3 by Ex-Member
Replied by Ex-Member on topic avro shackleton mk111
Great stuff Tony, I'll look forward to this one too!
04 Feb 2014 10:52 #4 by Fly-Navy
Replied by Fly-Navy on topic avro shackleton mk111
This will be one to watch, looking forward to it.
What was it they used to say about the Shack, "Forty thousand rivets flying in formation" [badass]
04 Feb 2014 14:31 #5 by Ex-Member
latest up date of the cad work. :)
bomb doors going in and the fuselage split designed in.
hope to get the pdf files soon and then we can start cutting bits.
  • Sarah-Jane Smith's Avatar
04 Feb 2014 14:37 #6 by Sarah-Jane Smith
Replied by Sarah-Jane Smith on topic avro shackleton mk111
brilliant, so thats how CAD works.
  • alan cantwell
  • alan cantwell's Avatar
  • Inactivated User
  • Inactivated User
04 Feb 2014 18:26 #7 by alan cantwell
Replied by alan cantwell on topic avro shackleton mk111
The good thing about Cad, is press a button, and you have a 20 foot one, hint, hint, best of luck Tony, i am sure you will get some interest, i do actually, fancy a glider version, at the size you are building
04 Feb 2014 18:42 #8 by Ex-Member
non of this is my work, it is all dylan's doing.
on its building jig.
my job starts soon, the first build from the pdf files.
then i can adjust things to make it build able and send the changes back so they can be incorporated into the new plan.
05 Feb 2014 06:19 #9 by Ex-Member
Looks good Tony.........
On the other hand, the jig looks very complicated. It's just a thought, but in the FF world when we build fuselages like that we use a threaded rod with tube spacers on it to hold the formers in place rather than a complex jig as shown. If a square section tube is slid over the rod, it'll hold the orientation of the formers, then square or round section tubes of appropriate length slid over that and inbetween the formers create the spacing. A bolt at each end holds it secure. When the fus is built, just remove the bolts, slide out the tube and there you have it.
As an aside, if the Whirlwind was my own design rather than a kit, then that's how I would have built it.
05 Feb 2014 09:02 #10 by Ex-Member
had a re think Andy and thee fuselage will be built in 2 halves.
that way it can be built flat on the table and joined before sheeting.
05 Feb 2014 19:53 #11 by Ex-Member
well thank you to Dylan at lasercraft services
i have a plan for the shack fuselage.
took some sorting out to get it printed off and i have the fun job of sticking it all together tomorrow.
not a good pic, but it gives you an idea of the size.
thas a 6ft x 4ft carpet.
06 Feb 2014 13:15 #12 by Ex-Member
cutting a couple of parts for the new start.
nose former ( first half) and the nose floor.
06 Feb 2014 17:43 - 06 Feb 2014 17:45 #13 by Ex-Member
spent all afternoon cutting two more plates and 2 more formers.
we were going to build the nose in two halve, but on reflection this is not necessary so the F1 was cut into quarters by mistake, still it all glued in ok.
then i started a small bit of construction, going well together with no real problems.
the nose will be constructed in one piece unlike the fuselage. that will be constructed in two halves and glued together before sheeting.
Last edit: 06 Feb 2014 17:45 by Ex-Member.
07 Feb 2014 18:10 #14 by Ex-Member
Well i finished hand cutting all the nose formers and plates.
so we had a gluing session.
so i am now starting to add all the stringers.
07 Feb 2014 20:06 #15 by Ex-Member
here is my previous attempt in its new home, or will be when i have painted it up and added some details.
Time to create page: 0.251 seconds
