Build-along-a Fury
  • Septic
  • Septic's Avatar Topic Author
11 Jul 2017 19:17 - 11 Jul 2017 19:22 #1 by Septic
Build-along-a Fury was created by Septic
Some of you loiter on the RCM&E forum as well as this one, and may have seen a build-along I started with a colleague a few years ago. We built a Dennis Bryant Chipmunk. The build has been great fun and the idea was to push your own limits beyound your comfort zone. For some just building from a plan was a first, others had never applied rivets or rib tapes and added detail to a model.
It was a great success and even though Only a half dozen of those started were completed lots was learned. There are still another two or three stragglers who are determined to finish.
Anyway I was Co-erced er bullied, Invited to run another such build. I have teamed up with that ever enthusiastic and very capable modeller Martyn K. Even our own mr Scale Andy Sephton is joining in!
The model is another Dennis Bryant (perhaps we should have learned our lesson on the DB Chipmunk :woohoo: Anyway we are older and wiser now. The model is 60" span and although the plan is for IC we will be doing electric too.
So if you fancy joining in then pop over to the RCM&E forum and let us know. I will try and do a build on here as I think Andy is going to do too.
As I say the model we have chosen is the Dennis Bryant Hawker Fury MkI and this could easily be tweaked into a Nimrod.
I have struck a deal with Craig at Traplet, and he is giving a 20 percent discount on top of the current sale price of plan, laser cut parts, cowl and spinner.
To be clear these are the individual numbers:
SKU: MW3453 Plan
SKU: WP3453 Wood pack, just the cut items, no stripwood or sheet
SKU: CF3453CL Cowl
SKU: CS3453SET Alloy Spinner
2727 3 view Line Drawing on which the plan is based
The first 4 are included in this set
SKU: SET3453
To qualify for the discount mention Quote 20% discount for the joint build" when you phone in your order.
The one thing I haven't mentioned is that the build will not be starting until October 2018, this gives everybody lots of time to clear the building boards and purchase bits and pieces for the build.
Hopefully we will all get together and have a squadron of Furies in the Air, possibly Greenacres or Old warden :)
Cheers
Danny
tap - tap.......rivet
Last edit: 11 Jul 2017 19:22 by Septic.
Thanks: Phil Wood, Klipkopwildlife, Quorneng, THE BLACKBIRD, blue123, boz, Squirrelnet
11 Jul 2017 20:57 #2 by Ex-Member
Replied by Ex-Member on topic Build-along-a Fury
I shall be watching with great interest sir Danny.
Hope fully to steal some good ideas and tips from you.
12 Jul 2017 09:27 - 12 Jul 2017 09:42 #3 by Ex-Member
Well, it looks like I'm well and truly in on this one, having ordered my set and three-view from Traplet this morning! ;) ;)
I'll be starting a thread on here and RCM&E when the build proper starts next year, and I'll make the decision then as to which one I'm building. Thoughts at the moment are split between the Cranwell training scheme and the replica aircraft I test flew some years ago that, I believe, currently resides in Belgium. The black and white fin and elevator should prove to be quite a challenge! ;) ;)
Last edit: 12 Jul 2017 09:42 by .
12 Jul 2017 09:47 #4 by Mike Rolls
Replied by Mike Rolls on topic Build-along-a Fury
Go on Andy - you know you want to - when it comes to buying the black and white dope for the tail, make sure that you get chequered, not striped!
Thanks: Ex-Member, , boz, Septic, Squirrelnet
12 Jul 2017 13:30 #5 by Ex-Member
The Hawker Fury is one Biplane i have always wanted to build i even started the plans back in oct 2016.
Looks like i will have to get them finished off and think about joining in, on the side sort of thing.
as mine is 1/4 scale and Depron, so it would not be fair on the others if i posted on here.
  • Septic
12 Jul 2017 14:18 - 12 Jul 2017 14:19 #6 by Septic
Replied by Septic on topic Build-along-a Fury
Hi Tony, it really isn't a mass build it is some experienced builders leading the way for some less experienced builders. Enabling them to have a crack at a model they are unsure they could build. Scale buddying I guess.
On the level of your skills, I don't think this is anything you need, but seeing yours come together will be fascinating all the same, you will also have input into the comparisons between a plan and docs and photos. This is all great information.
So please join in, the group will be stronger with you on board.
You do realise that if you cannot exceed the level of detail in my 1/6 Fury with your 1/4 scale behmoath then you will be sent to sit at the back of the class :whistle:
I appreciate this project is focussed on the RCM&E forum, but I am afraid that is who I write for. I haven't thrown it open to other forums as I usually do because this forum has some good people in it that enjoy building scale models.
The discount (available until 31/7/2017) is nearly 40% and I have done that deal personally with Traplet.
In just 24 hours since the launch 10 kits have been sold so the project will happen.
Cheers
Danny
Last edit: 12 Jul 2017 14:19 by Septic. Reason: typo
Thanks: Klipkopwildlife, Ex-Member, , boz, Firewood, Squirrelnet
12 Jul 2017 16:09 #7 by boz
Replied by boz on topic Build-along-a Fury
Although I won't be participating, I will be following the builds boz. :)
Thanks: , Firewood
13 Jul 2017 21:51 #8 by Ex-Member
30 Jul 2017 16:39 #9 by Ex-Member
I know the build has not started yet.
but if i leave the 3D design parts till the start date, it will be another year of designing before i can make a start. :P
so here is the mk1 instrument panel in 1/6th scale.
there are masses of bits that i want to print, so i shall work on them in the run up to the start date.
07 Aug 2017 22:55 #10 by Ex-Member
1/6th scale vickers machine gun.
need another one now.
09 Aug 2017 08:52 #11 by
Replied by on topic Build-along-a Fury
Put me down for two of those, please Tony! ;) ;)
  • Septic
10 Aug 2017 23:35 #12 by Septic
I will of course want some too Tony ;)
17 Aug 2017 17:49 #13 by Ex-Member
designed and printed some panel fittings today. ( between printing engine parts)
just test pieces, but i think they will look the part once glued onto the fuselage.
17 Aug 2017 17:49 #14 by Ex-Member
15 Feb 2018 13:14 #15 by Klipkopwildlife
Replied by Klipkopwildlife on topic Build-along-a Fury
Just an update, I contacted Sarik who replied saying they wanted to make up a full kit for me and would revert with the cost of carriage. This they did, 72.15Gbp. I then asked, was this 'to be signed for', no reply, nor any reply to my second e-mail!
My point is, do they actually want to sell kits or are they so busy they haven't the time to deal with me?
Time to create page: 0.270 seconds
