- Thank you received: 5
CO2 power
- Deezil Dynosoar
- New Member
10 Oct 2024 22:11 #1
by Deezil Dynosoar
CO2 power was created by Deezil Dynosoar
Please, can anyone help/provide information?
I've been bequeathed 3 Gasparin CO2 motors along with an early K&P charging adaptor and a green Sodastream Cylinder.
The cylinder's empty and is now an obsolete item.
The new cylinders have a different thread. The old one's 1/2" BSP and the new one is 6tpi Acme "square".
I need an adaptor that's a 1/2" BSP male one end and the 6tpi Acme female the other end if I'm to enjoy my inheritance using the new Sodastream cylinders.
Derek Knight emailed that he's too busy to spend time on such a project.
All help appreciated, Deezil.
10 Oct 2024 23:39 - 10 Oct 2024 23:40 #2
Replied by Quorneng on topic CO2 power
Deezil
It appears such an adapter does exist .
Soda Stream female Tr21-4 to Male Paintball G1/2-14 (0.825" - 14) which is 1/2" BSP but I have no idea if the Soda Stream thread is 6tpi Acme "Square" but all Soda Stream adapters use it.
A bit expensive to "try and see".
The most common Soda Stream adapter has a 21.8 -14 male thread, thus just under 1/2 BSP, that is used in home brewing.
Sorry I can't be more positive.
Last edit: 10 Oct 2024 23:40 by Quorneng.
Thanks: Klipkopwildlife, Deezil Dynosoar
- Thank you received: 14305
11 Oct 2024 07:29 #3
Replied by Eric on topic CO2 power
Sorry, can't help with that one, it's outside my field of knowledge. Good luck.
- Deezil Dynosoar
- New Member
11 Oct 2024 21:01 #4
by Deezil Dynosoar
Replied by Deezil Dynosoar on topic CO2 power
Thank you for your thoughts. I'd never have thought of the paintball aspect of it. I'll have a look around and find a supplier.
Regards, Deezil.
Regards, Deezil.
Time to create page: 0.228 seconds
