- Thank you received: 1164
Weekday job
- jon.in.swansea
- jon.in.swansea
They carefully removed the existing granite worktop after an 'expert' judged that it would cost more in labour and transport to re-cut it to work with a new layout than to start again (very likely with something else). Must be a secondary market for granite.
It might be interesting to carry on a side conversation about kitchen choices.
Try to have everything laid out in a way that creates maximum space, but with minimum walking up and down and round and round, to collect the various bits of equipment needed, the cooker, hot pans, the work-top, and the sink!
Things like putting the freezer next to the oven isn't a good idea, either!
- Thank you received: 10722
But once fitted most modern units are ok as long as they are fitted properly and stand on legs as they make the units solid standing, the weakness with all units are door hinges and how the fix to the door or the unit as this is where they get the hammer
I took my kitchen in Cyprus from England and fit it there, i designed my next doors villas kitchen for them and fit it, they bought it from Ikea in Cyprus
- jon.in.swansea
Not unlike discovering stuff in an archaeology dig....
- jon.in.swansea
- jon.in.swansea
The 1950 solution? Add wood batons and cover with plasterboard!
By the 1960s even the wood batons were rotten and the plasterboard just disintegrated!
Just had to rip it all off and start again. Lower the outside ground level to below the inside floor level as it was originally. An injected damp proof course and water proof cement based outside render. As of 2025 it is still standing.
- jon.in.swansea
Anyway - we decided to excavate the earth down to the base clay layer and create several short supporting walls to create a suspended wood floor system matching the existing. I was so angry with bank that I joined in with the wrecking bar and shovel to help sift quite a bit of the ~5m^3 of earth/rubble. The underfloor heating should go in tomorrow...
Say BOO in the wrong place, and you can be locked out of any/everything - if they get their way.
