Onboard cameras
Window will ask if you want to open it to view the files.
It will then show the folder DCIM. This folder has 2 more folders in it. PHOTO holds any pictures as JPG files, 100MEDIA holds any video as AVI files.
These files can be viewed directly and transferred to your PC for storage.
This is more or less the same routine as for a proper digital camera but they tend to have proper detailed instructions on how to do it!
Dont forget the Key Fob is on charge all the time it is pugged in whether or not the PC is actually switched on so don't forget to unplug it!
I would remove the chain but secure a line to the hole in the camera case to ensure it is not lost if the velco 'lets go'.
I look forward to seeing the resultls.
Simply highlight the file name(s) and press delete. It will ask for confirmation.
There is no recovery, when its gone its gone.
I don't use (trust?) the automated import feature so I physically 'drag' (it actually copies) the file(s) from cam to the desired folder on my PC.
This screen grab shows a video file on the cam about to be copied to "My videos" folder. When complete I just delete the file still showing on the cam folder on the right.
Its a bit of a 'belt and braces' approach but with the vast hard drives on PCs now if a file is transferred to an 'automatic' location it can be the very devil to find!
- Thank you received: 14470
