- Thank you received: 155
''Spruce Goose'', 8 engine laviathon of a model...
- Cpl Jones
- Senior Member
- R.C. aeroplane collector & flyer. FPV lover..
Cpl. Jones
Jah Baga I... thanks!.
Quorneng wrote: An amazing achievement but like many big IC models way over scale speed and even more so for the landing!
show me a model that flys at scale speed,
The Douglas Skyray in my avatar makes a pretty good job of it but it does look ridiculously slow!
- bogbeagle
- Senior Member
- Thank you received: 119
At 12 feet, the scale is tiny, so no hope of anything even remotely convincing. 1/18 scale.
I'll give you some figures later. Gotta go out.
- bogbeagle
- Senior Member
Even then, the radius of turn, at any given bank angle, would be out by a factor of 18, I think.
The only way to do it, is to make a fast, heavy model, then film it at a high frame-rate ... play back at an appropriately slow frame-rate.
Most scale indoor models fly at a scale speed Alan, and a lot of the outdoor FF models do as well. The problem occurs as soon as you put in the radio gear which increases the weight, which increases the flying speed.
You need to join us in the Velodrome next time we go there, probably November.
Andy
The Skyray had a landing speed of 134mph (196ft/sec).
It was 45ft long so it travelled 4.3 times in own length each second when landing.
Mine is 43" long (3.58ft) so its scale landing speed is 4.3x3.58 = 15.4 ft/sec or 10 mph.
It certainly seems to get down to that sort of speed at touch down however I am not sure it has a maximum 5.4 times as fast like the full size did!
An outdoor RC plane that flies at less than scale speed?
- bogbeagle
- Senior Member
Unless my reasoning is wrong, of course.
- Monz
