radio control dangers eg, lipos and ic
Garry Pollard wrote: A thought has just occured to me, how many peeps who drive cars worry about the petrol in the tank. There is a bomb waiting to go off...........
The difference between petrol in the tank and a lipo is that the lipo can spontaneously combust whereas petrol need an ignition source.
- Sangoma
Garry Pollard wrote: Most things can hurt you if misused, and lipos are no exception. Treat them with caution and you SHOULD be ok. Mine are charged in the garage on a concrete floor, and although I do leave them, I can see/hear from the house and I keep checking. Storage, mine are packed in a plastic box and put in a steel box till needed. A thought has just occured to me, how many peeps who drive cars worry about the petrol in the tank. There is a bomb waiting to go off. Be sensible and you should be ok, but be ready for the unexpected.
I used to have a VW 412 Variant, the fuel tank was in the front "boot", and it was always on my mind.
Some years before I saw a head on between a 412 and a Chev Komando (A big Holden) The front wheels of the 412 were halfway back the front doors, the fuel tank burst and caught fire, and a friend of mine burnt his arms trying to pull the driver out. He was stuck fast though.
I like fuel tanks at the back, under a steel floor
Before that, when we had petrol restrictions we used to carry 5 20l cooking oil tins of petrol in the front of a Renault R10. Wouldn't do it now!!
In the same way gross over charging a car battery releases hydrogen and oxygen gas in exactly an explosive mix. :ohmy:
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
What do I need to buy to keep my lipos safe in a couple of weeks then?
- Sarah-Jane Smith
- Gone
You can store them in whatever state of charge in a metal tin, (biscuit tin, etc) with the lid on, but you HAVE to make sure that the connectors cannot touch the tin, or each other!
For something to put them on while you charge them - anything that won't burn, ie an old baking tray, or a stone paving flag. But don't do the charging next to the couch, or under the dining table!
- Sarah-Jane Smith
- Gone
- pikpilot
I had a 2s1p2100 battery that was just showing signs of bulging. There was hardly any pressure inside so I used a small needle to let out the gas, being very careful not to stick the lipo itself.
It immediately started to smoke and as I threw it through an upstairs window it caught fire. Not only did the smoke and fire on the front lawn attract attention, during the next few minutes the battery burnt a hole in lawn down by about 2-3 inches.
I now keep all my lipos in biscuit tins on the rear patio, away from everything else. During the winter they are stored at 50% charge and at whatever temperature the weather dictates. Over 3 years the batteries do not appear to deteriorated by over wintering this way.
I use a charger that chargers each cell separately through the "balancer" connection.
One of our club members lost his large shed and all his models, transmitters etc through a lipo fire while charging. Luckily the shed was in the garden and well away from the house. He lost everything but his insurance paid out many thousands so he was able to start again.
My belief is that some chargers that use bulk charging with built in balances are based on NiMh/Pb type chargers with add on balancers. I know from professional experience that series charging of cells can actually increase the amount of "out of step" between cells in a series string. With lipos you are are relying on the balancer being able to cope with gross differences between charge levels in order to avoid overcharging of a single cell.
Has anyone done any tests on balancers when connected to out of step cells?
I rather hoped people by now had grasped the concept that LiPos must not be abused in any way.
Let the gas out!
The thick plastic cell covering is there specifically to keep air out as Lithium burns readily.
If the inner cell structure is disrupted in any way it is likely to create a local short circuit which causes over heating so triggering more cell damage and shorting. Soon the covering melts, lets in the air and the Lithium burns.
It enters a sort 'run away' condition, as you discovered!
LiPos aren't dangerous.
People who use them........?
